Delta Electronics ASDA-Soft
Successful exploitation of this vulnerability could allow an attacker to execute arbitrary code.
The following versions of Delta Electronics ASDA-Soft are affected:
  • ASDA-Soft <=V7.2.2.0
v3 7.8 Delta Electronics Delta Electronics ASDA-Soft Stack-based Buffer Overflow
  • Company Headquarters Location: Taiwan
CVE-2026-5726
A stack-based buffer overflow vulnerability is triggered in ASDA-Soft version 7.2.0.0 during the parsing of malformed .par files.
Delta Electronics
Delta Electronics ASDA-Soft: <=V7.2.2.0
Delta Electronics recommends users download and upgrade ASDA-Soft to v7.2.6.0 or later. If you have any product-related support concerns, contact Delta via the portal page at https://www.deltaww.com/en-US/service-support/contact-us?type=1 for any information or materials you may require.
Delta Electronics provides the following general recommendations: Do not click on untrusted internet links or open unsolicited attachments in emails. Avoid exposing control systems and equipment to the Internet. Place control system networks and remote devices behind firewalls, and isolate them from the business network. When remote access is required, use a secure access method, such as a virtual private network (VPN).
For more information, see Delta Electronics advisory Delta-PCSA-2026-00007 athttps://filecenter.deltaww.com/news/download/doc/Delta-PCSA-2026-00007_ASDA-Soft%20Stack-based%20Buffer%20Overflow%20Vulnerability%20(CVE-2026-5726).pdf
  • Feng Xiong of TrendAI Zero Day Initiative reported this vulnerability to CISA
  • Initial Release Date: 2026-04-16
2026-04-16 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-106-01
