Designing a Client Network with OSPF - Multi Part
[CENTER]
https://www.youtube.com/watch?v=TZpfF6swgX0
[/CENTER]
Network Assumptions
For this tutorial we are going to assume the following: [ul] [li]Physical Layout[/li][LIST] [li]We have 3 buildings[/li][LIST] [li]Building 1 (1 switch) - building-1a[/li][LIST] [li]ports 1-10 - staff access[/li][li]ports 11-15 - guest access[/li][li]ports 16-17 - wireless access points[/li][li]ports 18-19 - connect to building-2a[/li][li]ports 20-21 - unused[/li][li]ports 22-23 - connect to building-3a[/li][li]ports 24 -[/li][/ul] [li]Building 2 (1 switch) - building-2a[/li][ul] [li]ports 1-10 - staff access[/li][li]ports 11-15 - guest access[/li][li]ports 16-17 - wireless access points[/li][li]ports 18-19 - connect to building-1a[/li][li]ports 20-21 - connect to building-3a[/li][li]ports 22-24 - unused [I](currently)[/I][/li][/ul] [li]Building 3 (1 switch) - building-3a[/li][ul] [li]ports 1-10 - staff access[/li][li]ports 11-15 - guest access[/li][li]ports 16-19 - wireless access points[/li][li]ports 20-21 - connect to building-2a[/li][li]ports 22-23 - connect to building-1a[/li][li]ports 24 - connect to fw-3[/li][/ul] [/LIST] [/LIST] [li]- VLAN Configuration[/li][ul] [li]Default (1)[/li][li]STAFF (10)[/li][li]VOICE (20)[/li][li]GUEST (99)[/li][/ul] [li]Subnet Configuration[/li][ul] [li]building1[/li][LIST] [li]STAFF - 10.10.0.0/24[/li][LIST] [li]Gateway: 10.10.0.1[/li][li]DHCP Range: 10.10.0.50 - 10.10.0.254[/li][/ul] [li]VOICE - 10.20.0.0/24[/li][ul] [li]Gateway: 10.20.0.1[/li][li]DHCP Range: 10.20.0.50 - 10.20.0.254[/li][/ul] [li]GUEST - 10.99.0.0/24[/li][ul] [li]Gateway: 10.99.0.1[/li][li]DHCP Range: 10.99.0.2 - 10.99.0.254[/li][/ul] [/LIST] [li]building2[/li][ul] [li]STAFF - 10.10.20.0/24[/li][LIST] [li]Gateway: 10.10.20.1[/li][li]DHCP Range: 10.10.20.50 - 10.10.20.254[/li][/ul] [li]VOICE - 10.20.20.0/24[/li][ul] [li]Gateway: 10.20.20.1[/li][li]DHCP Range: 10.20.20.50 - 10.20.20.254[/li][/ul] [li]GUEST - 10.99.20.0/24[/li][ul] [li]Gateway: 10.99.20.1[/li][li]DHCP Range: 10.99.20.2 - 10.99.20.254[/li][/ul] [/LIST] [li]building3[/li][ul] [li]STAFF - 10.10.30.0/24\[/li][LIST] [li]Gateway: 10.10.30.1\[/li][li]DHCP Range: 10.10.30.50 - 10.10.30.254\[/li][/ul] [li]VOICE - 10.20.30.0/24\[/li][ul] [li]Gateway: 10.20.30.1\[/li][li]DHCP Range: 10.20.30.50 - 10.20.30.254\[/li][/ul] [li]GUEST - 10.99.30.0/24\[/li][ul] [li]Gateway: 10.99.30.1\[/li][li]DHCP Range: 10.99.30.2 - 10.99.30.254[/li][/ul] [/LIST] [/LIST] [/LIST]
Build Physical Network Layout
Use the configurations above to build the physical layout in GNS3 or EVE-NG. The Watchguard has been configured with 8 ports and each switch has been configured with 25 ports (the max allowed, and takes in account the MGMT interface).
Configure pfSense [I](or other firewall)[/I]
This is not an in depth configuration of pfSense, there are plenty of good examples out there.
Create Default Network
In this example we are going to use port 0 as the WAN and it will be DHCP, and then port 1 will be our LAN on subnet - 10.0.0.254/24
Create Address Aliases
[ul] [li]StaffNetwork with the subnets[/li][li]VoiceNetwork with the subnets[/li][li]GuestNetwork with the subnets[/li][/ul]
Create Port Aliases
- 80, 443, 53 (Guest)
Hybrid Outbound NAT
- Add aliases with Outbound Nat rules
Firewall
[ul] [li]Allow staff network to access LAN address of pfsense[/li][li]Configure Firewall rules to allow outbound traffic for the StaffNetwork (all traffic) and GuestNetwork (TCP/UDP of port alias)[/li][/ul]
Install FRR
Use package manager to install FRR during the install you must creat area first, then interface then set your OSPF and Global settings to enabled, also make sure to check that the following are checked. [ul] [li]Redistribute Default[/li][li]Always Redistribute[/li][/ul]
Configure the Routers
Lets start with building 3 becuase its where the internet is connected
Building 3 Configure VLANS
Lets first start by naming our switch [CODE]configure snmp sysName building-3a [/CODE] Now, lets create our vlans. [CODE]create vlan STAFF tag 10 description "STAFF NETWORK" create vlan VOICE tag 20 description "VOICE NETWORK" create vlan GUEST tag 99 description "GUEST NETWORK" [/CODE] now lets configure our ports on this switch lets start by confuring the ap ports [CODE]configure vlan 1 add ports 16-19 untagged configure vlan 10 add ports 16-19 tagged configure vlan 99 add ports 16-19 tagged [/CODE] now lets configure the rest of the access ports (staff and guest) [CODE]configure vlan 10 add ports 1-10 untagged configure vlan 99 add ports 11-15 untagged configure vlan 20 add ports 1-19 tagged [/CODE] at this point I would suggest saving by typing [CODE]save [/CODE] and hitting [ICODE]enter[/ICODE] then pressying "Y" and hitting [ICODE]enter[/ICODE] again
Configure Default VLAN and start the OSPF config
Lets add our ipaddresses to our management vlan [ICODE]1[/ICODE] and enable ipforwarding. [CODE]configure vlan 1 ipaddress 10.0.0.30/24 enable ipforwarding vlan 1 [/CODE] Lets configure OSPF on the first switch, this is not an IP address but in my case I'm going to use the router's ip address. [CODE]configure ospf routerid 10.0.0.30 configure ospf add vlan Default area 0.0.0.0 link-type broadcast enable ospf [/CODE] save your configuration again. If you did everything correctly if you use [ICODE]show ospf neighbor[/ICODE] you should see something similar to below [CODE]Neighbor ID Pri State ... Address 10.0.0.254 1 FULL /BDR 10.0.0.254 ... Total number of neighbors: 1 (All neighbors in Full state) [/CODE] and if you run [ICODE]show iproute[/ICODE] you should see something like [CODE]Ori Destination Gateway Mtr ... #o2 Default Route 10.0.0.254 10 ... #d 10.0.0.0/24 10.0.0.10 1 ... #o2 192.168.1.0/24 10.0.0.254 20 ... [/CODE] The last entry being my lan thats visable from the pfSense box. However if you power on a VM connected to any switch at this point you still won't have network access and thats because we don't have any DHCP configured. so lets configure the staff network with dhcp and add it to our OSPF area [CODE]configure vlan STAFF ipaddress 10.10.30.1/24 enable dhcp ports 1-10 vlan STAFF configure vlan STAFF dhcp-address-range 10.10.30.50 - 10.10.30.254 configure vlan STAFF dhcp-options default-gateway 10.10.30.1 configure vlan STAFF dhcp-options dns-server primary 208.67.222.222 configure vlan STAFF dhcp-options dns-server secondary 208.67.220.220 enable ipforwarding vlan 10 configure ospf add STAFF area 0.0.0.0 link-type broadcast [/CODE] You should now have network connection on your desktop vm connected to port 2 on building-3a. Lets go ahead and do the same for the voice and guest networks. [CODE]configure vlan VOICE ipaddress 10.20.30.1/24 enable dhcp ports 1-19 vlan VOICE configure vlan VOICE dhcp-address-range 10.20.30.50 - 10.20.30.254 configure vlan VOICE dhcp-options default-gateway 10.20.30.1 configure vlan VOICE dhcp-options dns-server primary 208.67.222.222 configure vlan VOICE dhcp-options dns-server secondary 208.67.220.220 enable ipforwarding vlan 20 confiugre ospf add VOICE area 0.0.0.0 link-type broadcast configure vlan GUEST ipaddress 10.99.30.1/24 enable dhcp ports 11-15 vlan GUEST configure vlan GUEST dhcp-address-range 10.99.30.2 - 10.99.30.254 configure vlan GUEST dhcp-options default-gateway 10.99.30.1 configure vlan GUEST dhcp-options dns-server primary 208.67.222.222 configure vlan GUEST dhcp-options dns-server secondary 208.67.220.220 enable ipforwarding vlan 99 configure ospf add GUEST area 0.0.0.0 link-type broadcast [/CODE] now would be a good time to save again while you're checking your pfsense box for the routes. Now lets navigate over to building 1 and get it configured
Building 1
Again we're going to create our vlans [CODE]configure snmp sysName building-1a create vlan STAFF tag 10 description "STAFF NETWORK" create vlan VOICE tag 20 description "VOICE NETWORK" create vlan GUEST tag 99 description "GUEST NETWORK" [/CODE] now lets configure our ports on this switch lets start by confuring the ap ports [CODE]configure vlan 1 add ports 16-17 untagged configure vlan 10 add ports 16-17 tagged configure vlan 99 add ports 16-17 tagged [/CODE] now lets configure the rest of the access ports (staff and guest) [CODE]configure vlan 10 add ports 1-10 untagged configure vlan 99 add ports 11-15 untagged configure vlan 20 add ports 1-17 tagged [/CODE] and save now we're going to configure our mangement ip address and ospf [CODE]configure vlan 1 ip address 10.0.0.10/24 enable ipforwarding vlan 1 configure ospf routerid 10.0.0.10 configure ospf add vlan Default area 0.0.0.0 link-type broadcast enable ospf [/CODE] and now we configure our VLANs for this building
Staff
[CODE]configure vlan STAFF ipaddress 10.10.0.1/24 enable dhcp ports 1-10,16-17 vlan STAFF configure vlan STAFF dhcp-address-range 10.10.0.50 - 10.10.0.254 configure vlan STAFF dhcp-options default-gateway 10.10.0.1 configure vlan STAFF dhcp-options dns-server primary 208.67.222.222 configure vlan STAFF dhcp-options dns-server secondary 208.67.220.220 enable ipforwarding vlan 10 configure ospf add STAFF area 0.0.0.0 link-type broadcast [/CODE]
VOICE
[CODE]configure vlan VOICE ipaddress 10.20.0.1/24 enable dhcp ports 1-17 vlan VOICE configure vlan VOICE dhcp-address-range 10.20.0.50 - 10.20.0.254 configure vlan VOICE dhcp-options default-gateway 10.20.0.1 configure vlan VOICE dhcp-options dns-server primary 208.67.222.222 configure vlan VOICE dhcp-options dns-server secondary 208.67.220.220 enable ipforwarding vlan 20 configure ospf add VOICE area 0.0.0.0 link-type broadcast [/CODE]
GUEST
[CODE]configure vlan GUEST ipaddress 10.99.0.1/24 enable dhcp ports 11-17 vlan GUEST configure vlan GUEST dhcp-address-range 10.99.0.2 - 10.99.0.254 configure vlan GUEST dhcp-options default-gateway 10.99.0.1 configure vlan GUEST dhcp-options dns-server primary 208.67.222.222 configure vlan GUEST dhcp-options dns-server secondary 208.67.220.220 enable ipforwarding vlan 99 configure ospf add GUEST area 0.0.0.0 link-type broadcast [/CODE] and save again
Building 2
Switch building-2a
Again we're going to create our vlans [CODE]configure snmp sysName building-2a create vlan STAFF tag 10 description "STAFF NETWORK" create vlan VOICE tag 20 description "VOICE NETWORK" create vlan GUEST tag 99 description "GUEST NETWORK" [/CODE] now lets configure our ports on this switch lets start by confuring the ap ports [CODE]configure vlan 1 add ports 16-17 untagged configure vlan 10 add ports 16-17 tagged configure vlan 99 add ports 16-17 tagged [/CODE] now lets configure the rest of the access ports (staff and guest) [CODE]configure vlan 10 add ports 1-10 untagged configure vlan 99 add ports 11-15 untagged configure vlan 20 add ports 1-17 tagged [/CODE] and save now we're going to configure our mangement ip address and ospf [CODE]configure vlan 1 ip address 10.0.0.20/24 enable ipforwarding vlan 1 configure ospf routerid 10.0.0.20 configure ospf add vlan Default area 0.0.0.0 link-type broadcast enable ospf [/CODE] and now we configure our VLANs for this building [B]Staff[/B] [CODE]configure vlan STAFF ipaddress 10.10.20.1/24 enable dhcp ports 1-10,16-17 vlan STAFF configure vlan STAFF dhcp-address-range 10.10.20.50 - 10.10.20.254 configure vlan STAFF dhcp-options default-gateway 10.10.20.1 configure vlan STAFF dhcp-options dns-server primary 208.67.222.222 configure vlan STAFF dhcp-options dns-server secondary 208.67.220.220 enable ipforwarding vlan 10 configure ospf add STAFF area 0.0.0.0 link-type broadcast [/CODE] [B]VOICE[/B] [CODE]configure vlan VOICE ipaddress 10.20.20.1/24 enable dhcp ports 1-17 vlan VOICE configure vlan VOICE dhcp-address-range 10.20.20.50 - 10.20.20.254 configure vlan VOICE dhcp-options default-gateway 10.20.20.1 configure vlan VOICE dhcp-options dns-server primary 208.67.222.222 configure vlan VOICE dhcp-options dns-server secondary 208.67.220.220 enable ipforwarding vlan 20 configure ospf add VOICE area 0.0.0.0 link-type broadcast [/CODE] [B]GUEST[/B] [CODE]configure vlan GUEST ipaddress 10.99.20.1/24 enable dhcp ports 11-15 vlan GUEST configure vlan GUEST dhcp-address-range 10.99.20.2 - 10.99.20.254 configure vlan GUEST dhcp-options default-gateway 10.99.20.1 configure vlan GUEST dhcp-options dns-server primary 208.67.222.222 configure vlan GUEST dhcp-options dns-server secondary 208.67.220.220 enable ipforwarding vlan 99 configure ospf add GUEST area 0.0.0.0 link-type broadcast [/CODE] and save again
Video for Part 2
[CENTER]
https://www.youtube.com/watch?v=PDs2HIOFGZY
[/CENTER]
