Successful exploitation of these vulnerabilities could allow an attacker to remotely execute arbitrary code and bypass ASLR.
The following versions of EnOcean SmartServer IoT are affected:
- SmartServer IoT <=4.60.009 (CVE-2026-20761, CVE-2026-22885)
| v3 8.1 | EnOcean Edge Inc | EnOcean SmartServer IoT | Improper Neutralization of Special Elements used in a Command ('Command Injection'), Out-of-bounds Read |
- Critical Infrastructure Sectors: Information Technology
CVE-2026-20761
A vulnerability exists in EnOcean SmartServer IoT version 4.60.009 and prior, which would allow remote attackers, in the LON IP-852 management messages, to send specially crafted IP-852 messages resulting in arbitrary OS command execution on the device.
EnOcean Edge Inc
EnOcean Edge Inc SmartServer IoT: <=4.60.009
EnOcean recommends users update the SmartServer platform software to SmartServer 4.6 Update 2 (v4.60.023) or a later release at:
http://https//enoceanwiki.atlassian.net/wiki/spaces/IEC/pages/5275672/SmartServer+Release+Notes#Current-Stable-Release
For additional mitigations and workarounds, refer to EnOcean's hardening guide at: https://enoceanwiki.atlassian.net/wiki/spaces/IEC/pages/288063529/Enhancing+Security.
Relevant CWE: CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection')
| 3.1 | 8.1 | HIGH | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:H |
CVE-2026-22885
A vulnerability exists in EnOcean SmartServer IoT version 4.60.009 and prior, which would allow remote attackers, in the LON IP-852 management messages, to send specially crafted IP-852 messages resulting in a memory leak from the program's memory.
EnOcean Edge Inc
| 3.1 | 3.7 | LOW | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:L/I:N/A:N |
- Amir Zaltzman of Claroty Team82 reported these vulnerabilities to CISA
No known public exploitation specifically targeting these vulnerabilities has been reported to CISA at this time. These vulnerabilities have a high attack complexity.
- Initial Release Date: 2026-02-19
| 2026-02-19 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-050-01
