ePower epower.ie
The following versions of ePower epower.ie are affected:
  • epower.ie vers:all/*
v3 9.4 ePower ePower epower.ie Missing Authentication for Critical Function, Improper Restriction of Excessive Authentication Attempts, Insufficient Session Expiration, Insufficiently Protected Credentials
  • Critical Infrastructure Sectors: Energy, Transportation Systems
  • Company Headquarters Location: Ireland
CVE-2026-22552
ePower epower.ie
ePower
ePower epower.ie: vers:all/*
ePower did not respond to CISA's request for coordination. Contact ePower using their contact page here: https://www.epower.ie/support/ for more information.
3.1 9.4 CRITICAL CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L
CVE-2026-27778
ePower epower.ie
ePower
CVE-2026-24912
ePower epower.ie
ePower
CVE-2026-27770
ePower epower.ie
ePower
  • Khaled Sarieddine and Mohammad Ali Sayed reported these vulnerabilities to CISA
  • Initial Release Date: 2026-03-03
2026-03-03 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-062-07
