EV2GO ev2go.io
Successful exploitation of these vulnerabilities could allow attackers to impersonate charging stations, hijack sessions, suppress or misroute legitimate traffic to cause large-scale denial of service, and manipulate data sent to the backend.
The following versions of EV2GO ev2go.io are affected:
  • ev2go.io vers:all/* (CVE-2026-24731, CVE-2026-25945, CVE-2026-20895, CVE-2026-22890)
v3 9.4 EV2GO EV2GO ev2go.io Missing Authentication for Critical Function, Improper Restriction of Excessive Authentication Attempts, Insufficient Session Expiration, Insufficiently Protected Credentials
  • Critical Infrastructure Sectors: Energy, Transportation Systems
  • Company Headquarters Location: United Kingdom
CVE-2026-24731
EV2GO ev2go.io
EV2GO
EV2GO ev2go.io: vers:all/*
EV2GO did not respond to CISA's request for coordination. Contact EV2GO using their contact page here: https://ev2go.io/ for more information.
3.1 9.4 CRITICAL CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L
CVE-2026-25945
EV2GO ev2go.io
EV2GO
CVE-2026-20895
EV2GO ev2go.io
EV2GO
CVE-2026-22890
EV2GO ev2go.io
EV2GO
  • Khaled Sarieddine and Mohammad Ali Sayed reported these vulnerabilities to CISA
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-057-04
