The following versions of Everon OCPP Backends are affected:
- api.everon.io vers:all/*
| v3 9.4 | Everon | Everon OCPP Backends | Missing Authentication for Critical Function, Improper Restriction of Excessive Authentication Attempts, Insufficient Session Expiration, Insufficiently Protected Credentials |
- Critical Infrastructure Sectors: Energy, Transportation Systems
- Company Headquarters Location: Netherlands
CVE-2026-26288
Everon
Everon api.everon.io: vers:all/*
Everon has shut down their platform on December 1st, 2025.
| 3.1 | 9.4 | CRITICAL | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L |
CVE-2026-24696
Everon
CVE-2026-20748
Everon
| 3.1 | 7.3 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:L |
CVE-2026-27027
Everon
| 3.1 | 6.5 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:N |
- Khaled Sarieddine and Mohammad Ali Sayed reported these vulnerabilities to CISA
- Initial Release Date: 2026-03-03
| 2026-03-03 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-062-08
