- CVSS v3 7.5
- Vendor: Festo
- Equipment: CPX-CEC-C1 and CPX-CMXX
- Vulnerability: Improper Privilege Management
Successful exploitation of this vulnerability could allow unauthenticated, remote access to critical webpage functions which may cause a denial of service.
Festo reports that the following products are affected:
- Festo Firmware installed on Festo Hardware Control block CPX-CEC-C1: Versions 2.0.12 and prior
- Festo Firmware installed on Festo Hardware Control block CPX-CMXX: Versions 1.2.34 rev.404 and prior
- Festo Firmware installed on Festo Hardware Control block-SET CPX-CEC-C1: Versions 1.2.34 rev.404 and prior
3.2.1 IMPROPER PRIVILEGE MANAGEMENT CWE-269
Festo control block CPX-CEC-C1 and CPX-CMXX in multiple versions allow unauthenticated, remote access to critical webpage functions which may cause a denial of service.
CVE-2022-3079 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
Rob Hulsebos and Daniel dos Santos of Forescout reported this vulnerability to Festo.
Festo has identified the following specific remediations users can apply to reduce risk:
- Limit access to the webserver (TCP port 80) of the device to what is absolutely necessary.
- Currently, no fix is planned.
- Replace CPX-CEC-C1 with the follow-up product CPX-CEC-C1-V3.
- Replace CPX-CMXX with the follow-up product CPX-CEC-M1-V3.
For more information, see the associated Festo security advisory FSA-202207: Festo: CPX-CEC-C1 and CPX-CMXX, Missing Authentication for Critical Webpage Function - HTML and FSA-202207: Festo: CPX-CEC-C1 and CPX-CMXX, Missing Authentication for Critical Webpage Function - CSAF.
- When remote access is required, use more secure methods, such as virtual private networks (VPNs). Recognize VPNs may have vulnerabilities, should be updated to the most recent version available, and are only as secure as the connected devices.
- September 30, 2025: Initial Republication of Festo FSA-202207
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-273-03
