Gardyn Home Kit
Successful exploitation of these vulnerabilities could allow unauthenticated users to access and control edge devices, access cloud-based devices and user information without authentication, and pivot to other edge devices managed in the Gardyn cloud environment.
The following versions of Gardyn Home Kit are affected:
  • Home Kit Firmware
  • Gardyn Home Kit Mobile Application <2.11.0 (CVE-2025-29628, CVE-2025-29629, CVE-2025-29631, CVE-2025-1242)
  • Gardyn Home Kit Cloud API <2.12.2026 (CVE-2025-29628, CVE-2025-29629, CVE-2025-29631, CVE-2025-1242)
v3 9.1 Gardyn Gardyn Home Kit Cleartext Transmission of Sensitive Information, Use of Default Credentials, Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection'), Use of Hard-coded Credentials
  • Critical Infrastructure Sectors: Food and Agriculture
  • Countries/Areas Deployed: United States
CVE-2025-29628
A Gardyn Azure IoT Hub connection string is downloaded over an insecure HTTP connection leaving the string vulnerable to interception and modification through a Man-in-the-Middle attack. This may result in the attacker capturing device credentials or taking control of vulnerable home kits.
Gardyn Home Kit
Gardyn
Gardyn Home Kit Firmware:
Gardyn states that the relevant fixes are included in the latest version of the Gardyn mobile application. Users are required to run a supported version of the Gardyn App on their phone in order to access Gardyn services and devices.
The current versions of the Gardyn App and the Gardyn Home firmware can be checked in the Gardyn App.
For all vulnerabilities, Gardyn recommends users ensure their home kit devices are upgraded to firmware master.619 or later. Gardyn also recommends that users update their mobile application to the most recent version. Gardyn requests that users ensure their home kits have network connectivity in order to automatically download needed firmware updates. Unconnected devices will automatically update when configured with a working Internet connection.
Further information on Gardyn security can be found here: https://mygardyn.com/security/
Further customer support can be obtained from Gardyn at: [email protected]
3.1 8.3 HIGH CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:L
CVE-2025-29629
The Gardyn Home Kit uses weak default credentials for secure shell access. This may result in attackers gaining access to exposed Gardyn Home Kits.
Gardyn Home Kit
Gardyn
Relevant CWE: CWE-1392 Use of Default Credentials
CVE-2025-29631
The Gardyn Home Kit is vulnerable to command injection through vulnerable methods that do not sanitize input before passing content to the operating system for execution. The vulnerability may allow an attacker to execute arbitrary operating system commands on a target Home Kit.
Gardyn Home Kit
Gardyn
For CVE-2025-29631: Gardyn is currently working on a full mitigation to address this vulnerability. As previously stated, Gardyn recommends that users ensure their devices are always updated to the most current firmware version.
3.1 9.1 CRITICAL CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:N
CVE-2025-1242
The administrative credentials can be extracted through application API responses, mobile application reverse engineering, and device firmware reverse engineering. The exposure may result in an attacker gaining full administrative access to the Gardyn IoT Hub exposing connected devices to malicious control.
Gardyn Home Kit
Gardyn
Relevant CWE: CWE-798 Use of Hard-coded Credentials
  • Michael Groberman reported these vulnerabilities to CISA
  • Initial Release Date: 2026-02-24
2026-02-24 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-055-03
