Successful exploitation of these vulnerabilities may allow code execution with elevated privileges.
The following versions of GE Vernova Enervista UR Setup are affected:
- Enervista UR Setup <8.70 (CVE-2026-1762, CVE-2026-1763)
| v3 7.8 | GE Vernova | GE Vernova Enervista UR Setup | Uncontrolled Search Path Element, Path Traversal: '.../...//' |
- Critical Infrastructure Sectors: Critical Manufacturing, Energy, Water and Wastewater
CVE-2026-1762
The GE Vernova Enervista UR Setup Installer for versions prior to 8.70 are vulnerable to DLL hijacking. When running the installer in a location with unknown or untrusted DLLs, an attacker could obtain code execution with administrative privileges.
GE Vernova
GE Vernova Enervista UR Setup: <8.70
GE Vernova recommends affected users to use patched versions of Enervista UR Setup: Versions 8.70 or later (https://www.gevernova.com/grid-solutions/resources?prod=urfamily&type=7).
Relevant CWE: CWE-427 Uncontrolled Search Path Element
| 3.1 | 7.8 | HIGH | CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H |
CVE-2026-1763
GE Vernova Enervista UR Setup versions prior to 8.70 are vulnerable to directory traversal when opening certain firmware update files. This could allow an attacker to write to some files on the filesystem with the privileges of the logged-in user.
GE Vernova
Relevant CWE: CWE-35 Path Traversal: '.../...//'
| 3.1 | 3.3 | LOW | CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:N/I:L/A:N |
- Reid Wightman of Dragos reported these vulnerabilities to CISA
- Initial Release Date: 2026-02-17
| 2026-02-17 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-048-03
