General Network Diagnostics
I wanted a way to standardize the tests that our techs run when troubleshooting network issues. I’ve started this script as a beginning though I intend for it to be an EXE in the long run.
    .NOTES
     Created on:       12/10/2022 10:37 PM
     Created by:       WizardTux
     Organization:     IT Bible (itbible.org)
     Filename:
    .DESCRIPTION
        A description of the file.
$Domains = @(
    "google.com",
    "itbible.org"
$Resolvers = @(
    "208.67.222.222",
    "8.8.8.8"
$Gateway = Get-NetRoute | where { $_.DestinationPrefix -eq '0.0.0.0/0' } | Select -index 0 | select -ExpandProperty NextHop
$Externals = @(
    "8.8.8.8"
    "208.67.222.222"
function Run-DnsCustom
    param (
        [bool]$clear = $true
    if ($clear) { [System.Console]::Clear() }
    $DnsInput = Read-Host "Custom DNS lookup"
    if ($DnsInput)
        $ResolverInput = Read-Host "Custom Resolver [Local]"
        Write-Host "Testing DNS... Please wait..."
        if ($ResolverInput)
            Write-Host "Testing Custom DNS using $ResolverInput : $DnsInput" -ForegroundColor Yellow -BackgroundColor Black
            Resolve-DnsName -Name $DnsInput -Server $ResolverInput
        else
            Write-Host "Testing Custom DNS using Local Resolver: $DnsInput" -ForegroundColor Yellow -BackgroundColor Black
        if ($clear) { Pause }
        Exit
    Exit
function Run-Dns
    param (
    Write-Host "Testing Local DNS" -ForegroundColor Yellow -BackgroundColor Black
    foreach ($domain in $Domains)
        Resolve-DnsName -Name $domain -DnsOnly
    Write-Host ""
    Write-Host "Testing Remote DNS" -ForegroundColor Yellow -BackgroundColor Black
    $rCount = 0
    foreach ($resolver in $Resolvers)
        if ($rCount -gt 0) { Write-Host "" }
        Write-Host "Resolver: $resolver" -ForegroundColor DarkRed
            Resolve-DnsName -Name $domain -Server $resolver
        $rCount++
function Run-Trace
    param (
    Write-Host "Testing Traceroute... Please wait..."
    Write-Host "Tracing Gateway (should return 1 hop)" -ForegroundColor Yellow -BackgroundColor Black
    Test-NetConnection -TraceRoute -ComputerName $Gateway
    Write-Host ""
    Write-Host "Tracing Remote Addresses" -ForegroundColor Yellow -BackgroundColor Black
    $tCount = 0
    foreach ($external in $Externals)
        if ($tCount -gt 0) { Write-Host "" }
        Write-Host "Tracing: $external"
        Test-NetConnection -TraceRoute -ComputerName $external
function Run-PingCustom
    param (
    $PingInput = Read-Host "Custom Address"
    if ($PingInput)
        Write-Host "Testing PING... Please wait..."
        Test-Connection -ComputerName $PingInput -Count 4
        Exit
    #start powershell { dns.ps1 }
    Exit
function Run-Ping
    param (
        [bool]$clear=$true
    if($clear) { [System.Console]::Clear() }
    Write-Host "Testing Ping... Please wait..."
    Write-Host "Pinging Gateway: $Gateway" -ForegroundColor Yellow -BackgroundColor Black
    Test-Connection -ComputerName $Gateway -Count 4
    Write-Host ""
    Write-Host "Pinging External: $($Externals[0])" -ForegroundColor Yellow -BackgroundColor Black
    Test-Connection -ComputerName $Externals[0] -Count 4
function Run-All
    Write-Host "Testing All... Please wait..."
    Run-Ping -clear $false
    Run-Trace -clear $false
    Run-Dns -clear $false
    Pause
function Show-Menu
    param (
        [string]$Title = "ITBible Menu"
    Write-Host "================ $Title ================"
    Write-Host "Enter a number for diagnostic selection."
    Write-Host "1: Run all network Scripts" -ForegroundColor DarkGray
    Write-Host "2: Ping Test"
    Write-Host "2a: Custom Ping Test"
    Write-Host "3: Trace Test"
    Write-Host "4: DNS Test"
    Write-Host "4a: Custom DNS Test"
    Write-Host ""
    Write-Host "Q: Quit"
do
    Show-Menu -Title "ITBible Network Diag"
    $UserInput = Read-Host "Please make a selection"
    switch ($UserInput)
        '1' { Run-All }
        '2' { Run-Ping }
        '2a' { Run-PingCustom }
        '3' { Run-Trace }
        '4' { Run-Dns }
        '4a' { Run-DnsCustom }
until ($UserInput -eq 'q')
Any updates to this script can be found on our GitHub.
