Pretty simple script that will answer to what process is using a port.
param(
[Parameter(Mandatory=$true)]
[string]$port #e.g. 443
# Pull PID from TCP Connections and then outputs process name(s)
$pids = (Get-NetTCPConnection | Where-Object { $_.LocalPort -eq $port }) | Select-Object -Property OwningProcess
$pids | ForEach-Object { Get-Process -PID $_.OwningProcess | Select-Object -Property Name }
Updated a bit takes the output and keeps it from reporting multiple of the same service.
.NOTES
Created on: 12/10/2022 12:45 AM
Created by: WizardTux
Organization: IT Bible (itbible.org)
Filename: GetProcessByPort.ps1
.DESCRIPTION
Gets a list of processes using a specific port and outputs the list.
param (
[Parameter(Mandatory = $true)]
[string]$Port # e.g. 443
$pids = (Get-NetTCPConnection | Where-Object { $_.LocalPort -eq $Port }) | Select-Object -Property OwningProcess
$lastName=""
foreach ($localpid in $pids)
$current = Get-Process -PID $localpid.OwningProcess | Select-Object -Property ProcessName, Id
if ($current.ProcessName -ne $lastName)
$current
$lastName = $current.ProcessName
I want to keep this available as it updates so any future updates will be here.
