Güralp Systems FMUS Series and MIN Series Devices (Update A)
  • CVSS v4 9.3
  • Vendor: Güralp Systems
  • Equipment: Güralp FMUS Series and MIN Series Devices
  • Vulnerability: Missing Authentication for Critical Function
Successful exploitation of this vulnerability could allow an attacker to modify hardware configurations, manipulate data, or factory reset the device.
The following versions of Güralp FMUS series are affected:
  • Güralp FMUS Series Seismic Monitoring Devices : All versions
  • Güralp MIN Series Digitizing Devices : All versions
The affected products expose an unauthenticated Telnet-based command line interface that could allow an attacker to modify hardware configurations, manipulate data, or factory reset the device.
CVE-2025-8286 has been assigned to this vulnerability. A CVSS v3 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-8286. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • COMPANY HEADQUARTERS LOCATION: United Kingdom
Souvik Kandar reported this vulnerability to CISA.
Güralp did not respond to CISA's attempts at coordination. Users of Güralp are encouraged to contact Güralp and keep their systems up to date.
  • July 31, 2025: Initial Publication
  • August 14, 2025: Update A - Added an additional product, edited the executive summary, edited the title, and revised the researcher section.
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-212-01
