Hitachi Energy RTU500 Product
Hitachi Energy is aware of vulnerabilities that affect RTU500 product versions listed in this document. Successful exploitation of these vulnerabilities can result in the exposure of low-value user management information and device outage. Please refer to the Recommended Immediate Actions for information about the mitigation/remediation.
The following versions of Hitachi Energy RTU500 Product are affected:
  • RTU500 series CMU Firmware vers:RTU500_series_CMU_Firmware/>=12.7.1|<=12.7.7, vers:RTU500_series_CMU_Firmware/>=13.5.1|<=13.5.4, vers:RTU500_series_CMU_Firmware/>=13.6.1|<=13.6.2, vers:RTU500_series_CMU_Firmware/>=13.7.1|<=13.7.7, 13.8.1
v3 7.5 Hitachi Energy Hitachi Energy RTU500 Product Improper Handling of Insufficient Permissions or Privileges , Incomplete List of Disallowed Inputs, Uncontrolled Recursion, Allocation of Resources Without Limits or Throttling
CVE-2026-1772
RTU500 web interface: An unprivileged user can read user management information. The information cannot be accessed via the RTU500 web user interface but requires further tools like browser development utilities to access them without required privileges.
Hitachi Energy
RTU500 series CMU Firmware version 12.7.1 through 12.7.7, RTU500 series CMU Firmware version 13.5.1 through 13.5.4, RTU500 series CMU Firmware version 13.6.1 through 13.6.2, RTU500 series CMU Firmware version 13.7.1 through 13.7.7, RTU500 series CMU Firmware version 13.8.1
Update to CMU Firmware version 12.7.8
Follow general mitigation factors/workarounds
Update to CMU Firmware version 13.7.8 or latest
Update to CMU Firmware version 13.8.2
Relevant CWE: CWE-280 Improper Handling of Insufficient Permissions or Privileges
3.1 4.3 MEDIUM CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:L/I:N/A:N
CVE-2026-1773
IEC 60870-5-104: Potential Denial of Service impact on reception of invalid U-format frame. Product is only affected if IEC 60870-5-104 bi-directional functionality is configured. Enabling secure communication following IEC 62351-3 does not remediate the vulnerability but mitigates the risk of exploitation.
Hitachi Energy
Relevant CWE: CWE-184 Incomplete List of Disallowed Inputs
CVE-2024-8176
A stack overflow vulnerability exists in the libexpat library due to the way it handles recursive entity expansion in XML documents. When parsing an XML document with deeply nested entity references, libexpat can be forced to recurse indefinitely, exhausting the stack space and causing a crash. This issue could lead to denial of service (DoS) or, in some cases, exploitable memory corruption, depending on the environment and library usage. Product is only affected if IEC61850 functionality is configured.
Hitachi Energy
Relevant CWE: CWE-674 Uncontrolled Recursion
CVE-2025-59375
libexpat in Expat before 2.7.2 allows attackers to trigger large dynamic memory allocations via a small document that is submitted for parsing. Product is only affected if IEC61850 functionality is configured.
Hitachi Energy
  • Hitachi Energy PSIRT reported these vulnerabilities to CISA.
Notice
The information in this document is subject to change without notice and should not be construed as a commitment by Hitachi Energy. Hitachi Energy provides no warranty, express or implied, including warranties of merchantability and fitness for a particular purpose, for the information contained in this document, and assumes no responsibility for any errors that may appear in this document. In no event shall Hitachi Energy or any of its suppliers be liable for direct, indirect, special, incidental or consequential damages of any nature or kind arising from the use of this document, or from the use of any hardware or software described in this document, even if Hitachi Energy or its suppliers have been advised of the possibility of such damages. This document and parts hereof must not be reproduced or copied without written permission from Hitachi Energy and the contents hereof must not be imparted to a third party nor used for any unauthorized purpose. All rights to registrations and trademarks reside with their respective owners.
Support
For additional information and support please contact your product provider or Hitachi Energy service organization. For contact information, see https://www.hitachienergy.com/contact-us/ for Hitachi Energy contact-centers.
General Mitigation Factors
Recommended security practices and firewall configurations can help protect a process control network from attacks that originate from outside the network. Such practices include that process control systems are physically protected from direct access by unauthorized personnel, have no direct connections to the Internet, and are separated from other networks by means of a firewall system that has a minimal number of ports exposed, and others that have to be evaluated case by case. Process control systems should not be used for Internet surfing, instant messaging, or receiving e-mails. Portable computers and removable storage media should be carefully scanned for viruses before they are connected to a control system. Proper password policies and processes should be followed.
This ICSA is a verbatim republication of Hitachi Energy PSIRT 8DBD000237 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Hitachi Energy PSIRT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-02-24
2026-02-24 1 Initial public release
2026-03-03 2 Initial CISA Republication of Hitachi Energy PSIRT 8DBD000237 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-062-03
