Hitachi Energy Service Suite
  • CVSS v4 9.3
  • Vendor: Hitachi Energy
  • Equipment: Service Suite
  • Vulnerability: Deserialization of Untrusted Data
Successful exploitation of this vulnerability could allow attackers to compromise Oracle WebLogic Server, resulting in potential impacts on confidentiality, integrity, and availability.
Hitachi Energy reports that the following products are affected:
  • Service Suite: Versions prior to 9.6.0.4 EP4
3.2.1 DESERIALIZATION OF UNTRUSTED DATA CWE-502
Easily exploitable vulnerability allows unauthenticated attacker with network access via IIOP, T3 to compromise Oracle WebLogic Server. Successful attacks of this vulnerability can result in takeover of Oracle WebLogic Server.
CVE-2020-2883 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2020-2883. A base score of 9.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • COMPANY HEADQUARTERS LOCATION: Switzerland
Hitachi Energy PSIRT reported this vulnerability to CISA.
Hitachi Energy has identified the following specific workarounds and mitigations users can apply to reduce risk:
  • Service Suite versions prior to 9.6.0.4 EP4: Update to version 9.8.2 or latest- Hitachi Energy recommends that customers apply the update at the earliest convenience - While reviewing the recommended immediate actions, assess the risk exposure of affected products within the operational environment and update or upgrade if necessary.
  • Service Suite versions prior to 9.6.0.4 EP4: Apply general Mitigation Factors.
For more information see the associated Hitachi Energy PSIRT security advisory 8DBD000215 Remote Code Execution Vulnerability in Hitachi Energy Service Suite Product.
  • September 18, 2025: Initial Republication of Hitachi Energy PSIRT 8DBD000215
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-261-05
