Successful exploitation of this vulnerability could allow an attacker to gain unauthorized access to systems and services.
The following versions of Horner Automation Cscape and XL4, XL7 PLC are affected:
- Cscape v10.0
- XL7 PLC v15.60
- XL4 PLC v16.32.0
| v3 9.1 | Horner Automation | Horner Automation Cscape and XL4, XL7 PLC | Weak Password Requirements |
CVE-2026-6284
An attacker with network access to the PLC is able to brute force discover passwords to gain unauthorized access to systems and services. The limited password complexity and no password input limiters makes brute force password enumeration possible.
Horner Automation
Horner Automation Cscape: v10.0, Horner Automation XL7 PLC: v15.60, Horner Automation XL4 PLC: v16.32.0
Horner Automation recommends users update to Cscape v10.2 SP2 or later. Horner Automation has also released the latest firmware for both XL4 and XL7 PLCs. Horner recommends users update to the latest version of the firmware. https://hornerautomation.com/cscape-software-free/cscape-software/.
For more information, see Horner Automation's release notes.
Relevant CWE: CWE-521 Weak Password Requirements
| 3.1 | 9.1 | CRITICAL | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:N |
- An anonymous researcher reported this vulnerability to CISA
- Initial Release Date: 2026-04-16
| 2026-04-16 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-106-02
