The following versions of IGL-Technologies eParking.fi are affected:
- eParking.fi vers:all/*
| v3 9.4 | IGL-Technologies | IGL-Technologies eParking.fi | Missing Authentication for Critical Function, Improper Restriction of Excessive Authentication Attempts, Insufficient Session Expiration, Insufficiently Protected Credentials |
- Critical Infrastructure Sectors: Energy, Transportation Systems
- Company Headquarters Location: Finland
CVE-2026-29796
IGL-Technologies
IGL-Technologies eParking.fi: vers:all/*
IGL-Technologies has updated eParking's OCPP servers to reduce the risks posed by the vulnerability. These updates implemented the following security controls:
1) Enforce modern security profiles and stronger authentication.
2) Device‑level whitelisting was implemented to ensure that only authorized charging units can connect.
3) Rate‑limiting controls prevent excessive requests and reduces DoS risk.
4) Enhanced automated monitoring and alerting to detection abnormal network activity.
Devices using the encrypted deployment of eParking's OCPP servers or IGL-Technologies proprietary eTolppa protocol are not impacted by these vulnerabilities.
To prevent this in the future IGL-Technologies will continue vulnerability monitoring under their ISO 27001:2022 security program and tighten security requirements for future third‑party OCPP hardware approvals.
For more information please contact the IGL-Technologies security team at this email address: [email protected].
mailto:[email protected]
| 3.1 | 9.4 | CRITICAL | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L |
CVE-2026-31903
IGL-Technologies
CVE-2026-32663
IGL-Technologies
| 3.1 | 7.3 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:L |
CVE-2026-31926
IGL-Technologies
| 3.1 | 6.5 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:N |
- Khaled Sarieddine and Mohammad Ali Sayed reported these vulnerabilities to CISA
- Initial Release Date: 2026-03-19
| 2026-03-19 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-078-07
