Successful exploitation of this vulnerability could allow an attacker to cause a failure within the operating system of the machine hosting the ICU tool.
The following versions of Johnson Controls Inc. iSTAR Configuration Utility (ICU) tool are affected:
- iSTAR Configuration Utility (ICU) tool (CVE-2025-26386)
| v3 7.1 | Johnson Controls Inc. | Johnson Controls Inc. iSTAR Configuration Utility (ICU) tool | Stack-based Buffer Overflow |
- Critical Infrastructure Sectors: Commercial Facilities, Critical Manufacturing, Energy, Government Services and Facilities, Transportation Systems
- Company Headquarters Location: Ireland
CVE-2025-26386
Under certain circumstances, a successful exploitation of this vulnerability could result in failure within the operating system of the machine hosting the ICU tool.
Johnson Controls Inc. iSTAR Configuration Utility (ICU) tool: <=6.9.7
Johnson Controls Inc. recommends the following:
Update the iSTAR Configuration Utility (ICU) tool to version 6.9.8
For more detailed mitigation instructions, please see Johnson Controls Product Security Advisory JCI-PSA-2025-08 v1 at the following location: https://www.johnsoncontrols.com/trust-center/cybersecurity/security-advisories
| 3.1 | 7.1 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:U/C:N/I:L/A:H |
- Tenable reported this vulnerability to CISA
- Initial Release Date: 2026-01-22
| 2026-01-22 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-022-04
