Johnson Controls iSTAR
  • Vendor: Johnson Controls Inc.
  • Equipment: iSTAR Ultra, iSTAR Ultra SE, iSTAR Ultra G2, iSTAR Ultra G2 SE, iSTAR Edge G2
  • Vulnerabilities: Improper Neutralization of Special Elements used in an OS Command
Successful exploitation of these vulnerabilities could result in unauthorized access to the device.
Johnson Controls reports the following products are affected:
  • iSTAR Ultra: Versions prior to 6.9.7.CU01
  • iSTAR Ultra SE: Versions prior to 6.9.7.CU01
  • iSTAR Ultra G2: Versions prior to 6.9.3
  • iSTAR Ultra G2 SE: Versions prior to 6.9.3
  • iSTAR Edge G2: Versions prior to 6.9.3
3.2.1 Improper Neutralization of Special Elements used in an OS Command CWE-78
Under certain circumstances a successful exploitation of this vulnerability could result in access to the device.
CVE-2025-43875 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-43875. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 Improper Neutralization of Special Elements used in an OS Command CWE-78
CVE-2025-43876 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-43876. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Critical Manufacturing, Energy, Government Facilities, Transportation Systems
Johnson Controls reported these vulnerabilities to CISA.
Johnson Controls recommends users complete the following actions to address these issues:
  • Upgrade iSTAR Ultra, and iSTAR Ultra SE to version 6.9.7.CU01 or greater.
  • Upgrade iSTAR Ultra G2, iSTAR Ultra G2 SE, and iSTAR Edge G2 to version 6.9.3 or greater.
For detailed mitigation instructions, see the Johnson Controls Product Security Advisories JCI-PSA-2025-14 and JCI-PSA-2025-15. Johnson Controls recommends implementing measures to minimize risks to all building automation systems.
Further ICS security notices and product security guidance are located at the Johnson Controls product security website.
Contact Johnson Controls Global Product Security.
  • When remote access is required, use more secure methods, such as virtual private networks (VPNs), recognizing VPNs may have vulnerabilities and should be updated to the most current version available. Also recognize VPN is only as secure as the connected devices.
  • December 11, 2025: Initial Republication of Johnson Controls JCI-PSA-2025-14 and JCI-PSA-2025-15.
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-345-01
