- CVSS v4 6.5
- Vendor: Johnson Controls Inc.
- Equipment: OpenBlue Mobile Web Application for OpenBlue Workplace
- Vulnerability: Direct Request ('Forced Browsing')
Successful exploitation of this vulnerability could allow an attacker to gain unauthorized access to sensitive information.
The following versions of Johnson Controls OpenBlue Mobile Web Application for OpenBlue Workplace are affected:
- OpenBlue Mobile Web Application for OpenBlue Workplace: Version 2025.1.2 and prior
3.2.1 DIRECT REQUEST ('FORCED BROWSING') CWE-425
Johnson Controls OpenBlue Mobile Web Application for OpenBlue Workplace versions 2025.1.2 and prior are vulnerable to a Direct Request exploit that could allow an attacker to gain unauthorized access to sensitive information.
CVE-2025-26381 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:C/C:H/I:L/A:N).
A CVSS v4 score has also been calculated for CVE-2025-26381. A base score of 6.5 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:P/PR:N/UI:N/VC:H/VI:L/VA:N/SC:H/SI:L/SA:N/E:U).
- CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Critical Manufacturing, Energy, Government Services and Facilities, Transportation Systems
- COMPANY HEADQUARTERS LOCATION: Ireland
Johnson Controls Inc. reported this vulnerability to CISA.
Johnson Controls Inc. recommends the following:
- Upgrade to patch level 2025.1.3 or above when available. Note: When this patch is applied, skip the below two steps.
- Disable the Mobile Application in Microsoft Internet Information Services (IIS) or Disable the mobile application within Microsoft Internet Information Services (IIS) at the application pool level.
- Use the primary OpenBlue Workplace web interface: To complete the tasks you've previously accomplished in OpenBlue Workplace Mobile interface, the primary Workplace web interface provides a subset of the Mobile functionality and is available here: [base url]/FMInteract/Default.aspx?DashboardType=Homepage.
- For more detailed mitigation instructions, please see Johnson Controls Product Security Advisory JCI-PSA-2025-05 v1 at the following location: https://www.johnsoncontrols.com/cyber-solutions/security-advisories
- December 04, 2025: Initial Republication of JCI-PSA-2025-05
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-338-03
