MicroDicom DICOM Viewer
  • CVSS v4 8.6
  • Vendor: MicroDicom
  • Equipment: DICOM Viewer
  • Vulnerability: Out-of-bounds Write
Successful exploitation of this vulnerability could allow an attacker to execute arbitrary code on affected installations of DICOM Viewer.
The following MicroDicom products are affected:
  • DICOM Viewer: Versions 2025.2 (Build 8154) and prior
DICOM Viewer suffers from an out-of-bounds write vulnerability. Remote attackers are able to exploit this issue to potentially execute arbitrary code on affected installations of DICOM Viewer. User interaction is required to exploit the vulnerability in that the user must either visit a malicious website or open a malicious DICOM file locally.
CVE-2025-5943 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-5943. A base score of 8.6 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Healthcare and Public Health
  • COMPANY HEADQUARTERS LOCATION: Bulgaria
Michael Heinzl reported this vulnerability to CISA.
MicroDicom recommends users update DICOM Viewer to version 2025.3 or later.
  • June 10, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-medical-advisories/icsma-25-160-01
