MICROSENS NMP Web+
  • CVSS v4 9.3
  • Vendor: MICROSENS
  • Equipment: NMP Web+
  • Vulnerabilities: Use of Hard-coded, Security-relevant Constants, Insufficient Session Expiration, Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal')
Successful exploitation of these vulnerabilities could allow an attacker to gain system access, overwrite files or execute arbitrary code.
The following versions of NMP Web+ are affected:
  • NMP Web+: Version 3.2.5 and prior
3.2.1 USE OF HARD-CODED, SECURITY-RELEVANT CONSTANTS CWE-547
The affected products could allow an unauthenticated attacker to generate forged JSON Web Tokens (JWT) to bypass authentication.
CVE-2025-49151 has been assigned to this vulnerability. A CVSS v3 base score of 9.1 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-49151. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.2 INSUFFICIENT SESSION EXPIRATION CWE-613
The affected products contain JSON Web Tokens (JWT) that do not expire, which could allow an attacker to gain access to the system.
CVE-2025-49152 has been assigned to this vulnerability. A CVSS v3 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-49152. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.3 IMPROPER LIMITATION OF A PATHNAME TO A RESTRICTED DIRECTORY ('PATH TRAVERSAL') CWE-22
The affected products could allow an unauthenticated attacker to overwrite files and execute arbitrary code.
CVE-2025-49153 has been assigned to this vulnerability. A CVSS v3 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-49153. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Tomer Goldschmidt and Noam Moshe of Claroty Team82 reported these vulnerabilities to CISA.
The German Federal Office for Information Security (BSI) CERT-Bund assisted coordination with MICROSENS.
MICROSENS recommends users to update to NMP Web+ Version 3.3.0 for Windows and Linux.
  • June 24, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-175-07
