Mitsubishi Electric GENESIS64 and ICONICS Suite products
Successful exploitation of these vulnerabilities could allow a local attacker to disclose SQL Server credentials used by the affected products and use them to disclose, tamper with, or destroy data, or to cause a denial-of-service (DoS) condition on the system.
The following versions of Mitsubishi Electric GENESIS64 and ICONICS Suite products are affected:
  • GENESIS64 <=10.97.3 (CVE-2025-14815, CVE-2025-14816)
  • ICONICS Suite <=10.97.3 (CVE-2025-14815, CVE-2025-14816)
  • MobileHMI <=10.97.3 (CVE-2025-14815, CVE-2025-14816)
  • Hyper Historian <=10.97.3 (CVE-2025-14815, CVE-2025-14816)
  • AnalytiX <=10.97.3 (CVE-2025-14815, CVE-2025-14816)
  • MC Works 64 vers:all/* (CVE-2025-14815, CVE-2025-14816)
  • GENESIS <=11.02 (CVE-2025-14815, CVE-2025-14816)
v3 8.8 Mitsubishi Electric Mitsubishi Electric GENESIS64 and ICONICS Suite products Cleartext Storage of Sensitive Information, Cleartext Storage of Sensitive Information in GUI
  • Company Headquarters Location: Japan, United States
CVE-2025-14815
When the local caching feature using SQLite is enabled and SQL authentication is used for the SQL Server authentication, the SQL Server credentials are stored in plaintext within the local SQLite file. This results in a vulnerability due to Cleartext Storage of Sensitive Information (CWE 312), which may lead to information disclosure, tampering, or denial of service (DoS).
Mitsubishi Electric
Mitsubishi Electric GENESIS64: <=10.97.3, Mitsubishi Electric ICONICS Suite: <=10.97.3, Mitsubishi Electric MobileHMI: <=10.97.3, Mitsubishi Electric Hyper Historian: <=10.97.3, Mitsubishi Electric AnalytiX: <=10.97.3, Mitsubishi Electric MC Works 64: vers:all/*, Mitsubishi Electric GENESIS: <=11.02, Mitsubishi Electric Iconics Digital Solutions GENESIS64: <=10.97.3, Mitsubishi Electric Iconics Digital Solutions ICONICS Suite: <=10.97.3, Mitsubishi Electric Iconics Digital Solutions MobileHMI: <=10.97.3, Mitsubishi Electric Iconics Digital Solutions Hyper Historian: <=10.97.3, Mitsubishi Electric Iconics Digital Solutions AnalytiX: <=10.97.3, Mitsubishi Electric Iconics Digital Solutions GENESIS: <=11.02
Mitsubishi Electric is releasing fixed version 10.98 or later for GENESIS64, ICONICS Suite, MobileHMI, Hyper Historian and AnalytiX. Please download the fixed version from the link "https://iconicsinc.my.site.com/community/s/resource-center/product-downloads" and install it. After installation, perform the following step (1) and (2). (1) In Workbench, open the “Configure Application(s) Settings” dialog. In the “Available Applications” list, uncheck the “Local Cache” column for applications. (2) Delete the files created by the local cache functionality from "C:\ProgramData\ICONICS\Cache\*.sdf". For more information on the fixed version, refer to the Mitsubishi Electric security advisory at "https://www.mitsubishielectric.co.jp/psirt/vulnerability/pdf/2025-023.pdf".
Mitsubishi Electric Iconics Digital Solutions is releasing fixed version 10.98 or later for GENESIS64, ICONICS Suite, MobileHMI, Hyper Historian and AnalytiX. Please download the fixed version from the link "https://iconicsinc.my.site.com/community/s/resource-center/product-downloads" and install it. After installation, perform the following step (1) and (2). (1) In Workbench, open the “Configure Application(s) Settings” dialog. In the “Available Applications” list, uncheck the “Local Cache” column for applications. (2) Delete the files created by the local cache functionality from "C:\ProgramData\ICONICS\Cache\*.sdf". For more information on the fixed version, refer to the Mitsubishi Electric Iconics Digital Solutions whitepaper on security vulnerabilities which can be found at "https://iconics.com/about/security/cert".
Mitsubishi Electric is releasing fixed version 11.03 or later for GENESIS. Please download the fixed version from the link "https://iconicsinc.my.site.com/community/s/resource-center/product-downloads" and install it. After installation, perform the following step (1) and (2). (1) In Workbench, open the “Configure Application(s) Settings” dialog. In the “Available Applications” list, uncheck the “Local Cache” column for applications. (2) Delete the files created by the local cache functionality from "C:\ProgramData\ICONICS\11\Cache\*.sqlite3". For more information on the fixed version, refer to the Mitsubishi Electric security advisory at "https://www.mitsubishielectric.co.jp/psirt/vulnerability/pdf/2025-023.pdf".
Mitsubishi Electric Iconics Digital Solutions is releasing fixed version 11.03 or later for GENESIS. Please download the fixed version from the link "https://iconicsinc.my.site.com/community/s/resource-center/product-downloads" and install it. After installation, perform the following step (1) and (2). (1) In Workbench, open the “Configure Application(s) Settings” dialog. In the “Available Applications” list, uncheck the “Local Cache” column for applications. (2) Delete the files created by the local cache functionality from "C:\ProgramData\ICONICS\11\Cache\*.sqlite3". For more information on the fixed version, refer to the Mitsubishi Electric Iconics Digital Solutions whitepaper on security vulnerabilities which can be found at "https://iconics.com/about/security/cert".
No fix planned
There are no plans to release fixed version for MC Works64. For users of MC Works64, refer to the Mitsubishi Electric security advisory "https://www.mitsubishielectric.co.jp/psirt/vulnerability/pdf/2025-023.pdf", and take the actions described there.
For customer of GENESIS64, ICONICS Suite, MobileHMI, Hyper Historian, and AnalytiX that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend performing the following step (1) and (2). (1) In Workbench, open the “Configure Application(s) Settings” dialog. In the “Available Applications” list, uncheck the “Local Cache” column for applications. (2) Delete the files created by the local cache functionality from "C:\ProgramData\ICONICS\Cache\*.sdf".
For customer of GENESIS that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend performing the following step (1) and (2). (1) In Workbench, open the “Configure Application(s) Settings” dialog. In the “Available Applications” list, uncheck the “Local Cache” column for applications. (2) Delete the files created by the local cache functionality from "C:\ProgramData\ICONICS\11\Cache\*.sqlite3".
For customer of MC Works 64, Mitsubishi Electric recommends performing the following step (1) and (2). (1)In Workbench, open the “Configure Application(s) Settings” dialog. In the “Available Applications” list, uncheck the “Local Cache” column for applications. (2) Delete the files created by the local cache functionality from "C:\ProgramData\ICONICS\Cache\*.sdf".
For customers of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend using Windows authentication instead of SQL authentication for the SQL server authentication method, to minimize the risk of exploiting this vulnerability.
For customers of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend configuring the PCs with the affected product installed so that only an administrator can log in, to minimize the risk of exploiting this vulnerability.
For customers of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend using the PCs with the affected product installed in the LAN and blocking remote login from untrusted networks and hosts, and from non-administrator users, to minimize the risk of exploiting this vulnerability.
For customers of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend blocking unauthorized access by using a firewall, virtual private network (VPN), etc. and allowing remote login only to administrator when internet access is required, to minimize the risk of exploiting this vulnerability.
For customers of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend restricting physical access to the PC with the affected product installed and to the network to which the PC is connected, to minimize the risk of exploiting this vulnerability.
For customers of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend preventing the user from clicking on web links in emails from untrusted sources, or from opening attachments in untrusted emails, to minimize the risk of exploiting this vulnerability.
Relevant CWE: CWE-312 Cleartext Storage of Sensitive Information
3.1 8.8 HIGH CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H
CVE-2025-14816
In the Hyper Historian Splitter feature of the affected products, when SQL authentication is used for the SQL Server authentication, the SQL Server credentials are displayed in plain text in the GUI. This results in a vulnerability due to Cleartext Storage of Sensitive Information in GUI (CWE‑317 ), which may lead to information disclosure, tampering, or denial‑of‑service (DoS).
Mitsubishi Electric
Mitsubishi Electric is releasing fixed version 10.98 or later for GENESIS64, ICONICS Suite, MobileHMI, Hyper Historian and AnalytiX. Please download the fixed version from the link "https://iconicsinc.my.site.com/community/s/resource-center/product-downloads" and install it. For more information on the fixed version, refer to the Mitsubishi Electric security advisory at "https://www.mitsubishielectric.co.jp/psirt/vulnerability/pdf/2025-023.pdf".
Mitsubishi Electric Iconics Digital Solutions is releasing fixed version 10.98 or later for GENESIS64, ICONICS Suite, MobileHMI, Hyper Historian and AnalytiX. Please download the fixed version from the link "https://iconicsinc.my.site.com/community/s/resource-center/product-downloads" and install it. For more information on the fixed version, refer to the Mitsubishi Electric Iconics Digital Solutions whitepaper on security vulnerabilities which can be found at "https://iconics.com/about/security/cert".
Mitsubishi Electric is releasing fixed version 11.03 or later for GENESIS. Please download the fixed version from the link "https://iconicsinc.my.site.com/community/s/resource-center/product-downloads" and install it. For more information on the fixed version, refer to the Mitsubishi Electric security advisory at "https://www.mitsubishielectric.co.jp/psirt/vulnerability/pdf/2025-023.pdf".
Mitsubishi Electric Iconics Digital Solutions is releasing fixed version 11.03 or later for GENESIS. Please download the fixed version from the link "https://iconicsinc.my.site.com/community/s/resource-center/product-downloads" and install it. For more information on the fixed version, refer to the Mitsubishi Electric Iconics Digital Solutions whitepaper on security vulnerabilities which can be found at "https://iconics.com/about/security/cert".
No fix planned
For customer of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend performing the following steps (1) and (2). (1) Change the permissions of HHSplitter.exe so that only trusted administrators can execute it. (2) Delete HHSplitter.exe from the system if it is unnecessary.
For customers of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend blocking unauthorized access by using a firewall, virtual private network (VPN), etc. and allowing remote login only to administrator when internet access is required, and from non-administrator users, to minimize the risk of exploiting this vulnerability.
For customers of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric and Mitsubishi Electric Iconics Digital Solutions recommend restricting physical access to the PC with the affected product installed and the network to which the PC is connected, to minimize the risk of exploiting this vulnerability.
Relevant CWE: CWE-317 Cleartext Storage of Sensitive Information in GUI
  • Mitsubishi Electric reported these vulnerabilities to CISA
This ICSA is a verbatim republication of Mitsubishi Electric V20251021-001, V20251029-001 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact CISA directly for any questions regarding this advisory.
  • Initial Release Date: 2026-04-07
2026-04-07 1 Initial Publication
2026-04-07 2 Initial CISA Republication of CISA V20251021-001, V20251029-001 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-097-01
