Mitsubishi Electric MELSEC iQ-F Series
  • CVSS v3 9.1
  • Vendor: Mitsubishi Electric
  • Equipment: MELSEC iQ-F Series
  • Vulnerability: Improper Validation of Specified Index, Position, or Offset in Input
Successful exploitation of this vulnerability could allow an attacker to read confidential information, cause a denial-of-service condition, or stop operations by sending specially crafted packets.
The following versions of Mitsubishi Electric MELSEC iQ-F Series are affected. Products with [Note *1] are sold in limited regions:
  • FX5U-xMy/z x=32, 64, 80, y=T, R, z=ES,DS, ESS, DSS: All versions
  • FX5UC-xMy/z x=32, 64, 96, y=T, z=D, DSS: All versions
  • FX5UC-32MT/DS-TS, FX5UC-32MT/DSS-TS, FX5UC-32MR/DS-TS: All versions
  • FX5UJ-xMy/z x=24, 40, 60, y=T, R, z=ES,DS,ESS,DSS: All versions
  • FX5UJ-xMy/ES-A[Note *1] x=24, 40, 60, y=T, R: All versions
  • FX5S-xMy/z x=30, 40, 60, 80[Note *1], y=T, R, z= ES,DS,ESS,DSS: All versions
3.2.1 IMPROPER VALIDATION OF SPECIFIED INDEX, POSITION, OR OFFSET IN INPUT CWE-1285
This vulnerability allows a remote attacker to read information in the product, cause a Denial-of-Service (DoS) condition in MELSOFT connection communication with Mitsubishi Electric FA products such as GX Works3 and GOT, or stop the operation of the CPU module (causing a DoS condition on the CPU module), by sending specially crafted packets. The product is needed to reset for recovery.
CVE-2025-3755 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.1 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:H).
Mitsubishi Electric reported this vulnerability to CISA.
Mitsubishi Electric recommends users take the following mitigation measures to minimize the risk of exploiting this vulnerability:
  • Use a firewall or virtual private network (VPN), etc. to prevent unauthorized access when Internet access is required.
  • Use within a LAN and block access from untrusted networks and hosts through firewalls.
  • Use IP filter function to block access from untrusted hosts.
  • Restrict physical access to the affected products and the LAN that is connected by them.
For details on the IP filter function, please refer to the following manual for each product.
"13.1 IP Filter Function" in the MELSEC iQ-F FX5 User's Manual (Communication)
Please download the manual from the following URL: https://www.mitsubishielectric.com/fa/download/index.html
For more information, see Mitsubishi Electric advisory 2025-003.
  • June 3, 2025: Initial Republication of Mitsubishi Electric 2025-003
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-153-03
