Mitsubishi Electric MELSOFT Update Manager
  • CVSS v3 8.1
  • Vendor: Mitsubishi Electric
  • Equipment: MELSOFT Update Manager
  • Vulnerabilities: Integer Underflow (Wrap or Wraparound), Protection Mechanism Failure
Successful exploitation of these vulnerabilities could allow an attacker to execute arbitrary code, disclose information, alter information, or cause a denial-of-service (DoS) condition.
The following versions of Mitsubishi Electric MELSOFT Update Manager are affected:
  • MELSOFT Update Manager SW1DND-UDM-M: Versions 1.000A to 1.012N
3.2.1 INTEGER UNDERFLOW (WRAP OR WRAPAROUND) CWE-191
Mitsubishi Electric MELSOFT Update Manager is vulnerable to an Integer Underflow vulnerability in 7-zip, included in MELSOFT Update Manager, that could allow a remote attacker to execute arbitrary code by decompressing a specially crafted compressed file. As a result, the attacker may disclose, tamper with information, or cause a denial-of-service (DoS) condition on the product.
CVE-2024-11477 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.1 has been calculated; the CVSS vector string is (AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:H).
3.2.2 PROTECTION MECHANISM FAILURE CWE-693
Mitsubishi Electric MELSOFT Update Manager is vulnerable to an Protection Mechanism Failure vulnerability in 7-zip, included in MELSOFT Update Manager, that could allow an attacker to execute arbitrary code by decompressing a specially crafted compressed file. As a result, the attacker may disclose, tamper with information, or cause a denial-of-service (DoS) condition on the product.
CVE-2025-0411 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
Mitsubishi Electric reported these vulnerabilities to CISA.
Mitsubishi Electric recommends users take the following actions to minimize the risk of exploiting these vulnerabilities.
For users in Japan:
  • Download version 1.013P or later from the download site below and follow the update procedure below (Note). Additionally, please verify the authenticity of the following download site in advance.
  • Download Site (in Japanese)
Update Procedure:
  • Extract the downloaded file (in zip format).
  • Run "setup.exe" in the extracted folder to install.
  • Note: If you are using MELSOFT Update Manager version 1.012N and prior, please do not connect to the internet until the above update is complete. There is a risk that these vulnerabilities could be exploited.
For users outside Japan:
  • For information about how to install the fixed version, please contact your local Mitsubishi Electric representative.
For users who cannot immediately update the product, Mitsubishi Electric recommends the following mitigation measures to minimize the risk of exploiting these vulnerabilities.
  • Use the PC with the affected product within the LAN and block remote logins from untrusted networks, hosts, and users.
  • When connecting the PC with the affected product to the internet, use a firewall, virtual private network (VPN), etc. to prevent unauthorized access and allow only trusted users to remote login.
  • Restrict physical access to the PC with the affected product and the network to which the PC is connected to, to prevent unauthorized physical access .
  • Do not click on web links in emails from untrusted sources. Also, do not open attachments in untrusted emails.
  • Install antivirus software on the PC with the affected product.
For more information, see Mitsubishi Electric 2025-006.
No known public exploitation specifically targeting these vulnerabilities has been reported to CISA at this time. These vulnerabilities have a high attack complexity.
  • July 3, 2025: Initial Republication of Mitsubishi Electric 2025-006
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-184-03
