- CVSS v4 7.1
- Vendor: National Instruments
- Equipment: LabVIEW
- Vulnerabilities: Improper Restriction of Operations within the Bounds of a Memory Buffer
Successful exploitation of these vulnerabilities could lead to the execution of arbitrary code on affected installations of LabVIEW, which could result in invalid memory reads.
The following versions of LabVIEW are affected:
- LabVIEW: 2025 Q1 and prior versions
3.2 Vulnerability Overview
3.2.1 IMPROPER RESTRICTION OF OPERATIONS WITHIN THE BOUNDS OF A MEMORY BUFFER CWE-119
LabVIEW 2025 Q1 and prior versions are affected by an improper restriction of operations within the bounds of a memory buffer vulnerability, which may allow a local attacker to disclose information and execute arbitrary code remotely, resulting in invalid memory reads.
CVE-2025-2633 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-2633. A base score of 7.1 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:P/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 IMPROPER RESTRICTION OF OPERATIONS WITHIN THE BOUNDS OF A MEMORY BUFFER CWE-119
LabVIEW 2024 Q3 and prior versions are affected by an improper restriction of operations within the bounds of a memory buffer vulnerability, which may allow a local attacker to disclose information and execute arbitrary code remotely, resulting in invalid memory reads.
CVE-2025-2634 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-2634. A base score of 7.1 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:P/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Michael Heinzl reported these vulnerabilities to CISA.
National Instruments has released the following patches for the affected products:
- For those affected by CVE-2025-2633 click here.
- For those affected by CVE-2025-2634 click here.
Please refer to the National Instruments advisory for further information.
- July 29, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-210-01
