Opto 22 groov View
  • CVSS v4 6.1
  • Vendor: Opto 22
  • Equipment: groov View
  • Vulnerability: Exposure of Sensitive Information Through Metadata
Successful exploitation of this vulnerability could result in credential exposure, key exposure, and privilege escalation.
The following versions of groov View are affected:
  • groov View Server for Windows: Versions R1.0a to R4.5d
  • GRV-EPIC-PR1 Firmware: Versions prior to 4.0.3
  • GRV-EPIC-PR2 Firmware: Versions prior to 4.0.3
3.2.1 Exposure of Sensitive Information Through Metadata CWE-1230
The users endpoint in the groov View API returns a list of all users and associated metadata including their API keys. This endpoint requires an Editor role to access and will display API keys for all users, including Administrators.
CVE-2025-13084 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.6 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:L/A:L).
A CVSS v4 score has also been calculated for CVE-2025-13084. A base score of 6.1 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:P/PR:L/UI:N/VC:H/VI:L/VA:L/SC:N/SI:N/SA:N).
Nik Tsytsarkin, Ismail Aydemir, and Ryan Hall of Meta reported this vulnerability to CISA.
Opto 22 has published a patch to address this vulnerability and recommends that users upgrade to groov View Server for Windows Version R4.5e and GRV-EPIC Firmware Version 4.0.3. Additional information is available from Opto 22 here.
  • November 25, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-329-04
