We just want to set a few posting guidelines for when you’re posting a question.
Make sure to mark it as the question type when posting.
This helps ensure that you get all of the correct options and lets everyone know you’re looking for an answer to something. With a few exceptions all forums should have the option to post a question.
Please be sure to check for the answer to your question before posting.
We may of already answered it before and this reduces clutter of the same question over and over again.
Mark the question as solved when its solved.
If someone posts the answer to your question be sure to mark it as the solution (it gives them points and helps their community standing).
Failure to follow guidelines.
If you fail to follow the guidelines outlined here your post may be deleted and repeated failure to follow them may result in a ban. These guidelines are subject to change without notice.
