Raisecomm RAX701-GC Series
  • CVSS v4 9.3
  • Vendor: Raisecomm
  • Equipment: RAX701-GC-WP-01 P200R002C52, RAX701-GC-WP-01 P200R002C53
  • Vulnerability: Authentication Bypass Using an Alternate Path or Channel
Successful exploitation of this vulnerability could allow a remote attacker to bypass authentication and gain unauthenticated root shell access to the affected devices.
The following versions of Raisecomm RAX701-GC products, are affected:
  • RAX701-GC-WP-01 P200R002C52: Firmware version 5.5.27_20190111
  • RAX701-GC-WP-01 P200R002C53: Firmware version 5.5.13_20180720 and version 5.5.36_20190709
3.2.1 AUTHENTICATION BYPASS USING AN ALTERNATE PATH OR CHANNEL CWE-288
The affected Raisecom devices allow SSH sessions to be established without completing user authentication. This could allow attackers to gain shell access without valid credentials.
CVE-2025-11534 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-11534. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Information Technology, Communications
  • COMPANY HEADQUARTERS LOCATION: China
HD Moore of runZero discovered this vulnerability and Tod Beardsley of runZero reported this vulnerability to CISA.
RaiseComm has not responded to requests to work with CISA to mitigate this vulnerability. Users of affected versions of RaiseComm products are invited to contact RaiseComm customer support for additional information.
  • October 21, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-294-06
