Rockwell Automation 1715 EtherNet/IP Comms Module
  • CVSS v4 7.7
  • Equipment: 1715 EtherNet/IP
  • Vulnerabilities: Allocation of Resources Without Limits or Throttling, Out-of-bounds Write
Successful exploitation of these vulnerabilities could allow an attacker to cause the web server to crash, requiring a restart to recover.
The following versions of Rockwell Automation 1715 EtherNet/IP Comms Module are affected:
  • 1715 EtherNet/IP: Versions 3.003 and prior
3.2.1 ALLOCATION OF RESOURCES WITHOUT LIMITS OR THROTTLING CWE-770
A denial-of-service security issue exists in the affected product and version. The security issue stems from a high number of requests sent to the web server. This could result in a web server crash; however, this does not impact I/O control or communication. A power cycle is required to recover and utilize the webpage.
CVE-2025-9177 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9177. A base score of 7.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:N/SC:N/SI:N/SA:H).
A denial-of-service security issue exists in the affected product and version. The security issue is caused through CIP communication using crafted payloads. The security issue could result in no CIP communication with 1715 EtherNet/IP Adapter. A restart is required to recover.
CVE-2025-9178 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9178. A base score of 7.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:N/SC:N/SI:N/SA:H).
Rockwell Automation has released the following for user implementation:
Users of the affected software who are unable to upgrade to one of the corrected versions should apply Rockwell Automation's security best practices.
For more information, see Rockwell Automation's advisory SD1757.
  • October 14, 2025: Initial Republication of Rockwell Automation advisory SD1757
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-287-01
