Rockwell Automation ControlLogix Ethernet Modules
  • CVSS v4 9.3
  • Equipment: ControlLogix Ethernet Modules
  • Vulnerability: Initialization of a Resource with an Insecure Default
Successful exploitation of this vulnerability could allow remote attackers to perform memory dumps, modify memory, and control execution flow.
The following versions of Rockwell Automation ControlLogix Ethernet Modules are affected:
  • 1756-EN2T/D: Version 11.004 and prior
  • 1756-EN2F/C: Version 11.004 and prior
  • 1756-EN2TR/C: Version 11.004 and prior
  • 1756-EN3TR/B: Version 11.004 and prior
  • 1756-EN2TP/A: Version 11.004 and prior
3.2.1 Initialization of a Resource with an Insecure Default CWE-1188
Rockwell Automation ControlLogix Ethernet Modules are vulnerable to a security issue where the web-based debugger agent is enabled by default on released devices. If a specific IP address is used to connect to the WDB agent, it can allow remote attackers to perform memory dumps, modify memory, and control execution flow.
CVE-2025-7353 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-7353. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Chemical, Energy, Critical Manufacturing, Food and Agriculture, Transportation Systems, Water and Wastewater Systems
Rockwell Automation recommends that ControlLogix Ethernet Module users update to Version 12.001 if possible. If users are unable to upgrade to Version 12.001, security best practices should be applied.
  • August 14, 2025: Initial Republication: Initial Republication of Rockwell Automation’s SD1732
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-28
