Rockwell Automation FactoryTalk ViewPoint
  • Equipment: FactoryTalk ViewPoint
  • Vulnerability: Improper Restriction of XML External Entity Reference
Successful exploitation of this vulnerability could allow unauthenticated attackers to achieve XML external entity injection, resulting in a temporary denial-of-service condition.
Rockwell Automation reports the following versions of PanelView Plus (which interacts with FactoryTalk ViewPoint) are affected by this vulnerability:
  • PanelView Plus 7 Terminal: Version 14 and prior
3.2.1 Improper Restriction of XML External Entity Reference CWE-611
A security issue was discovered within FactoryTalk ViewPoint, allowing unauthenticated attackers to achieve XML external entity injection. Certain SOAP requests can be abused resulting in a temporary denial-of-service.
CVE-2025-9066 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9066. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Critical Manufacturing, Energy, Food and Agriculture, Transportation Systems, and Water and Wastewater Systems
Rockwell Automation recommends that users upgrade to one of the following versions:
  • Panel View Plus 7 Standard and Panel View Plus 7 Performance Series A v12, v13, v14 patch AID BF30506 (firmware fix)
  • Panel View Plus 7 Performance Series B V14.103
Users of the affected software who are unable to upgrade to one of the corrected versions should use Rockwell Automation's security best practices.
For more information, see the Rockwell Automation advisory SD1752 for this vulnerability.
  • When remote access is required, use more secure methods, such as virtual private networks (VPNs), recognizing VPNs may have vulnerabilities and should be updated to the most current version available. Also recognize VPN is only as secure as the connected devices.
  • October 16, 2025: Initial Republication of Rockwell Automation security advisory SD1752
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-289-03
