Rockwell Automation Stratix IOS
  • CVSS v4 8.6
  • Equipment: Stratix IOS
  • Vulnerability: Injection
Successful exploitation of this vulnerability could allow an attacker to run malicious configurations without authentication.
The following versions of Stratix IOS are affected:
  • Stratix IOS: Versions 15.2(8)E5 and prior
3.2.1 IMPROPER NEUTRALIZATION OF SPECIAL ELEMENTS IN OUTPUT USED BY A DOWNSTREAM COMPONENT ('INJECTION') CWE-74
A security issue affecting multiple Cisco devices also directly impacts Stratix® 5410, 5700, and 8000 devices. This can lead to remote code execution by uploading and running malicious configurations without authentication.
CVE-2025-7350 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.6 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:R/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-7350. A base score of 8.6 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation has provided an update that mitigates this vulnerability. Users are recommended to update to version 15.2(8)E6 or later.
If users are not able to upgrade to the corrected version, Rockwell Automation recommends referring to their security best practices.
  • September 09, 2025: Initial Republication of Rockwell Automation advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-252-03
