Samsung HVAC DMS
  • CVSS v4 7.5
  • Vendor: Samsung
  • Equipment: HVAC DMS
  • Vulnerabilities: Execution After Redirect (EAR), Deserialization of Untrusted Data, Absolute Path Traversal, Use of Potentially Dangerous Function, Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal'), Relative Path Traversal
Successful exploitation of these vulnerabilities can lead to unauthenticated remote code execution.
The following versions of Samsung HVAC DMS, a software management platform, are affected:
  • Samsung HVAC DMS: Versions 2.0.0 to 2.3.13.0, Versions 2.5.0.17 to 2.6.14.0, Versions 2.7.0.15 to 2.9.3.5
3.2 Vulnerability Overview
3.2.1 EXECUTION AFTER REDIRECT (EAR) CWE-698
An execution after redirect in Samsung DMS (Data Management Server) allows attackers to execute limited functions without permissions. An attacker could compromise the integrity of the platform by executing this vulnerability.
CVE-2025-53077 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:L/A:L).
A CVSS v4 score has also been calculated for CVE-2025-53077. A base score of 6.9 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:L/VA:L/SC:N/SI:N/SA:N).
3.2.2 DESERIALIZATION OF UNTRUSTED DATA CWE-502
Deserialization of Untrusted Data in Samsung DMS (Data Management Server) allows attackers to execute arbitary code via write file to system.
CVE-2025-53078 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.0 has been calculated; the CVSS vector string is (AV:N/AC:H/PR:H/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-53078. A base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:H/AT:N/PR:H/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.3 ABSOLUTE PATH TRAVERSAL CWE-36
Absolute Path Traversal in Samsung DMS (Data Management Server) allows authenticated attacker (Administrator) to read sensitive files.
CVE-2025-53079 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.9 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:H/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-53079. A base score of 6.9 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:H/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
3.2.4 IMPROPER LIMITATION OF A PATHNAME TO A RESTRICTED DIRECTORY PATHNAME TO A A RESTRICTED DIRECTORY ('PATH TRAVERSAL') CWE-22
Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal') in Samsung DMS (Data Management Server) allows authenticated attackers to create arbitary files in unintended locations on the filesystem.
CVE-2025-53080 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.1 has been calculated; the CVSS vector string is (AV:N/AC:H/PR:L/UI:N/S:U/C:L/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-53080. A base score of 6.1 has been calculated; the CVSS vector string is (AV:N/AC:H/AT:N/PR:L/UI:N/VC:L/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.5 IMPROPER LIMITATION OF A PATHNAME TO A RESTRICTED DIRECTORY PATHNAME TO A RESTRICTED DIRECTORY ('PATH TRAVERSAL') CWE-22
An 'Arbitary File Creation' in Samsung DMS (Data Management Server) allows attackers to create arbitary files in unintended locations on the filesystem. Exploitation is restricted to specific, authorized private IP addresses.
CVE-2025-53081 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.3 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:U/C:L/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-53081. A base score of 7.2 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:L/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.6 RELATIVE PATH TRAVERSAL CWE-23
An 'Arbitary File Deletion' in Samsung DMS (Data Management Server) allows attackers to delete arbitary files from unintended locations on the filesystem. Exploitation is restricted to specific, authorized private IP addresses.
CVE-2025-53082 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.1 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-53082. A base score of 7.2 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Critical Manufacturing
  • COMPANY HEADQUARTERS LOCATION: South Korea
Noam Moshe of Claroty Team82 reported these vulnerabilities to CISA.
Samsung recommends users to contact a Samsung call center or installer for a software update.
This product is not intended to be connected to the Internet, so please disconnect it from the Internet. Refer to the following statement in the manual: "Use this product only in a separate dedicated network. Samsung Electronics is not liable for any problems caused by connecting it to the Internet or an intranet."
No known public exploitation specifically targeting these vulnerabilities has been reported to CISA at this time. These vulnerabilities have a high attack complexity.
  • July 29, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-210-02
