- CVSS v4 9.5
- Vendor: Schneider Electric
- Equipment: EcoStruxure IT Data Center Expert
- Vulnerabilities: Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection'), Insufficient Entropy, Improper Control of Generation of Code ('Code Injection'), Server-Side Request Forgery (SSRF), Improper Privilege Management, and Improper Restriction of XML External Entity Reference
Successful exploitation of these vulnerabilities could allow an attacker to disrupt operations and access system data.
Schneider Electric reports the following product is affected:
- EcoStruxure IT Data Center Expert: Versions v8.3 and prior
3.2 Vulnerability Overview
An improper neutralization of special elements used in an OS command ('OS command injection') vulnerability exists, which could cause unauthenticated remote code execution when a malicious folder is created via the HTTP web interface when enabled. HTTP is disabled by default.
CVE-2025-50121 has been assigned to this vulnerability. A CVSS v3.1 base score of 10.0 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-50121. A base score of 9.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:N/UI:N/VC:H/VI:H/VA:H/SC:H/SI:L/SA:H).
3.2.2 INSUFFICIENT ENTROPY CWE-331
An insufficient entropy vulnerability exists, which could cause the root password discovery when the password generation algorithm is reverse engineered with access to installation or upgrade artifacts.
CVE-2025-50122 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:A/AC:H/PR:N/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-50122. A base score of 8.9 has been calculated; the CVSS vector string is (CVSS:4.0/AV:A/AC:H/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:H/SI:L/SA:H).
3.2.3 IMPROPER CONTROL OF GENERATION OF CODE ('CODE INJECTION') CWE-94
An improper control of generation of code ('code injection') vulnerability exists, which could cause remote command execution by a privileged account when the server is accessed via a console and the hostname input is exploited.
CVE-2025-50123 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:P/AC:L/PR:H/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-50123. A base score of 7.2 has been calculated; the CVSS vector string is (CVSS:4.0/AV:P/AC:L/AT:P/PR:H/UI:N/VC:H/VI:H/VA:H/SC:H/SI:L/SA:H).
3.2.4 SERVER-SIDE REQUEST FORGERY (SSRF) CWE-918
A server-side request forgery (SSRF) vulnerability exists, which could cause unauthenticated remote code execution when the server is accessed via the network with knowledge of hidden URLs and manipulation of the host request header.
CVE-2025-50125 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:C/C:L/I:L/A:N).
A CVSS v4 score has also been calculated for CVE-2025-50125. A base score of 6.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:N/UI:N/VC:L/VI:L/VA:N/SC:L/SI:N/SA:N).
3.2.5 IMPROPER PRIVILEGE MANAGEMENT CWE-269
An improper privilege management vulnerability exists, which could cause privilege escalation when the server is accessed by a privileged account via a console and through exploitation of a setup script.
CVE-2025-50124 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.9 has been calculated; the CVSS vector string is (CVSS:3.1/AV:P/AC:H/PR:H/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-50124. A base score of 7.2 has been calculated; the CVSS vector string is (CVSS:4.0/AV:P/AC:H/AT:P/PR:H/UI:N/VC:H/VI:H/VA:H/SC:H/SI:L/SA:H).
3.2.6 IMPROPER RESTRICTION OF XML EXTERNAL ENTITY REFERENCE CWE-611
An improper restriction of XML external entity reference vulnerability exists, which could cause manipulation of SOAP API calls and XML external entities injection, resulting in unauthorized file access when the server is accessed via the network using an application account.
CVE-2025-6438 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:H/UI:N/S:C/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-6438. A base score of 5.9 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:H/UI:N/VC:H/VI:N/VA:N/SC:L/SI:N/SA:N).
- COMPANY HEADQUARTERS LOCATION: France
Jaggar Henry and Jim Becher of KoreLogic, Inc. reported these vulnerabilities to Schneider Electric.
- Schneider Electric EcoStruxure IT Data Center Expert Version 8.3 and prior: Version 9.0 of EcoStruxure IT Data Center Expert includes fixes for these vulnerabilities and is available upon request from Schneider Electric's Customer Care Center.
- If users choose not to apply the remediation provided above, they should immediately apply the following mitigations to reduce the risk of exploit:
- Harden the DCE instance according to the cybersecurity best practices documented in the EcoStruxure IT Data Center Expert Security Handbook
For more information see the associated Schneider Electric CPCERT security advisory SEVD-2025-189-01 EcoStruxure IT Data Center Expert - SEVD-2025-189-01 PDF Version, EcoStruxure IT Data Center Expert - SEVD-2025-189-01 CSAF Version.
- July 22, 2025: Initial Republication of Schneider Electric CPCERT SEVD-2025-189-01
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-203-06
