Schneider Electric EcoStruxure Foxboro DCS
Schneider Electric is aware of a vulnerability in its EcoStruxure Foxboro DCS Control Software on Foxboro DCS workstations and servers. Control Core Services and all runtime software, like FCPs, FDCs, and FBMs, are not affected. The EcoStruxure Foxboro DCS ([https://www.se.com/ww/en/product-range/63680-ecostruxure-foxboro-dcs/](https://www.se.com/ww/en/product-range/63680-ecostruxure-foxboro-dcs/)) product is an innovative family of fault-tolerant, highly available control components, which consolidates critical information and elevates staff capabilities to ensure flawless, continuous plant operation. Failure to apply the remediation provided below may risk deserialization of untrusted data, which could result in loss of confidentiality, integrity and potential remote code execution on the compromised workstation.
The following versions of Schneider Electric EcoStruxure Foxboro DCS are affected:
  • EcoStruxure Foxboro DCS vers:generic/
v3 6.5 Schneider Electric Schneider Electric EcoStruxure Foxboro DCS Deserialization of Untrusted Data
  • Critical Infrastructure Sectors: Commercial Facilities, Critical Manufacturing, Energy
CVE-2026-1286
A deserialization of untrusted data vulnerability exists that could lead to loss of confidentiality, integrity and potential remote code execution on workstation when an admin authenticated user opens a malicious project file.
Schneider Electric
EcoStruxure Foxboro DCS versions prior to CS8.1
fixed, known_affected
Version CS 8.1 of EcoStruxure Foxboro DCS includes a fix for this vulnerability and is available through [https://buyautomation.se.com/](https://buyautomation.se.com/) CS 8.1 requires FX-V3 licenses, standard upgrade procedures apply. A reboot is required for workstations and servers. Depending on the existing system version, online upgrade without production interruption might be possible. Schneider Electric recommends you work with your local field service representative or technical service consultant for further information.
If users choose not to apply the remediation provided above, they should immediately apply the following mitigations to reduce the risk of exploit: The vulnerability is attacked with manipulated data from external sources to the DCS computers. Examples for these are: * Configuration taglists * DirectAccess Scripts * Any partial or full Galaxy backups * Library files * Code snippets * ASCII files of any sort * Generally, any file getting from outside the DCS computer on a DCS computer. Only use data from trusted sources, check for correct file name endings on data files, check for reasonable file sizes for any files coming to the system, and check structured data for any fields or columns which might be unexpected. Check for unusual manipulations of data within data files and reject files containing unexpected data or structures. Use secure communication channels and encrypt communications when communicating outside the site network. Avoid and ban removable media (e.g. USB sticks or drives) Minimize count of users with engineering or administrative rights to DCS computers and ensure all interactions on DCS computers are executed with minimal user access rights. Consequently, isolating Foxboro DCS computers will help minimizing the risk of this vulnerability being exploited.
Relevant CWE: CWE-502 Deserialization of Untrusted Data
3.1 6.5 MEDIUM CVSS:3.1/AV:L/AC:L/PR:H/UI:R/S:U/C:H/I:H/A:H
  • Schneider Electric reported this vulnerability to CISA.
Schneider Electric strongly recommends the following industry cybersecurity best practices. https://www.se.com/us/en/download/document/7EN52-0390/ * Locate control and safety system networks and remote devices behind firewalls and isolate them from the business network. * Install physical controls so no unauthorized personnel can access your industrial control and safety systems, components, peripheral equipment, and networks. * Place all controllers in locked cabinets and never leave them in the “Program” mode. * Never connect programming software to any network other than the network intended for that device. * Scan all methods of mobile data exchange with the isolated network such as CDs, USB drives, etc. before use in the terminals or any node connected to these networks. * Never allow mobile devices that have connected to any other network besides the intended network to connect to the safety or control networks without proper sanitation. * Minimize network exposure for all control system devices and systems and ensure that they are not accessible from the Internet. * When remote access is required, use secure methods, such as virtual private networks (VPNs). Recognize that VPNs may have vulnerabilities and should be updated to the most current version available. Also, understand that VPNs are only as secure as the connected devices. For more information refer to the Schneider Electric Recommended Cybersecurity Best Practices document.
For More Information
This document provides an overview of the identified vulnerability or vulnerabilities and actions required to mitigate. For more details and assistance on how to protect your installation, contact your local Schneider Electric representative or Schneider Electric Industrial Cybersecurity Services: https://www.se.com/ww/en/work/solutions/cybersecurity/. These organizations will be fully aware of this situation and can support you through the process. For further information related to cybersecurity in Schneider Electric’s products, visit the company’s cybersecurity support portal page: https://www.se.com/ww/en/work/support/cybersecurity/overview.jsp
LEGAL DISCLAIMER
About Schneider Electric
Schneider's purpose is to create impact by empowering all to make the most of our energy and resources, bridging progress and sustainability for all. We call this Life Is On. Our mission is to be the trusted partner in sustainability and efficiency. We are a global industrial technology leader bringing world-leading expertise in electrification, automation and digitization to smart industries, resilient infrastructure, future-proof data centers, intelligent buildings, and intuitive homes. Anchored by our deep domain expertise, we provide integrated end-to-end lifecycle AI enabled industrial IoT solutions with connected products, automation, software and services, delivering digital twins to enable profitable growth for our customers. We are a people company with an ecosystem of 150,000 colleagues and more than a million partners operating in over 100 countries to ensure proximity to our customers and stakeholders. We embrace diversity and inclusion in everything we do, guided by our meaningful purpose of a sustainable future for all. www.se.com
This ICSA is a verbatim republication of Schneider Electric SEVD-2026-069-03 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Schneider Electric directly for any questions regarding this advisory.
  • Initial Release Date: 2026-03-10
2026-03-10 1 Original Release
2026-03-13 2 Updated remediation and mitigations section.
2026-03-24 3 Initial CISA Republication of Schneider Electric Security Notification SEVD-2026-069-03
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-083-02
