Schneider Electric EcoStruxure
  • CVSS v4 4.1
  • ATTENTION: Exploitable from an adjacent network
  • Vendor: Schneider Electric
  • Equipment: EcoStruxure
  • Vulnerabilities: Uncontrolled Resource Consumption, Exposure of Sensitive Information to an Unauthorized Actor
Successful exploitation of these vulnerabilities could allow an attacker to cause a denial-of-service condition or disclose sensitive credential data.
The following Schneider Electric products are affected:
  • EcoStruxure Building Operation Enterprise Server 7.x: Versions prior to 7.0.2.348
  • EcoStruxure Building Operation Enterprise Server 6.x: Versions prior to 6.0.4.10001 (CP8)
  • EcoStruxure Building Operation Enterprise Server 5.x: Versions prior to 5.0.3.17009 (CP16)
  • EcoStruxure Enterprise Server 7.x: Versions prior to 7.0.2.348
  • EcoStruxure Enterprise Server 6.x: Versions prior to 6.0.4.10001 (CP8)
  • EcoStruxure Enterprise Server 5.x: Versions prior to 5.0.3.17009 (CP16)
  • EcoStruxure Workstation 7.x: Versions prior to 7.0.2.348
  • EcoStruxure Workstation 6.x: Versions prior to 6.0.4.10001 (CP8)
  • EcoStruxure Workstation 5.x: Versions prior to 5.0.3.17009 (CP16)
3.2.1 UNCONTROLLED RESOURCE CONSUMPTION CWE-400
Uncontrolled resource consumption vulnerability exists that could cause a denial of service when an authenticated user sends a specially crafted request to a specific endpoint from within the BMS network
CVE-2025-8449 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.5 has been calculated; the CVSS vector string is (AV:A/AC:H/PR:L/UI:R/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-8449. A base score of 4.1 has been calculated; the CVSS vector string is (AV:A/AC:H/AT:N/PR:L/UI:P/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.2 EXPOSURE OF SENSITIVE INFORMATION TO AN UNAUTHORIZED ACTOR CWE-200
Exposure of sensitive information to an unauthorized actor vulnerability exists that could cause unauthorized access to sensitive credential data when an attacker is able to capture local SMB traffic between a valid user within the BMS network and the vulnerable products.
CVE-2025-8448 has been assigned to this vulnerability. A CVSS v3.1 base score of 2.3 has been calculated; the CVSS vector string is (AV:A/AC:H/PR:L/UI:R/S:U/C:L/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-8448. A base score of 1.0 has been calculated; the CVSS vector string is (AV:A/AC:H/AT:N/PR:L/UI:P/VC:L/VI:N/VA:N/SC:N/SI:N/SA:N).
Pentest Limited reported these vulnerabilities to Schneider Electric.
Schneider Electric recommends users to update to the following versions of Enterprise Server, Enterprise Central, and Workstation that include a fix for the vulnerabilities:
  • 7.0.2.348
  • 6.0.4.10001 (CP8)
  • 5.0.3.17009 (CP16)
To receive the patch:
If users choose not to apply the remediation provided above, they should immediately apply the following mitigations to reduce the risk of exploit:
  • Implement strong access controls to limit system access to authorized personnel.
  • Use multi factor authentication if using EBO version 7.0 or later
  • Use firewalls to segregate networks and protect the building management system
  • Regularly monitor system activity
For more information see the associated Schneider Electric CPCERT security advisory SEVD-2025-224-04.
  • September 11, 2025: Initial Republication of Schneider Electric SEVD-2025-224-04
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-254-08
