- CVSS v4 6.9
- Vendor: Schneider Electric
- Equipment: Modicon M340, BMXNOE0100, and BMXNOE0110
- Vulnerability: Files or Directories Accessible to External Parties
Successful exploitation of this vulnerability could allow attackers to prevent firmware updates and disrupt the webserver's proper behavior by removing specific files or directories from the filesystem.
- Modicon M340: All versions
- Modbus/TCP Ethernet Modicon M340 module: Versions prior to SV3.60
- Modbus/TCP Ethernet Modicon M340 FactoryCast module: Versions prior to SV6.80
3.2.1 FILES OR DIRECTORIES ACCESSIBLE TO EXTERNAL PARTIES CWE-552
A Files or Directories Accessible to External Parties vulnerability exists which may prevent user to update the device firmware and prevent proper behavior of the webserver when specific files or directories are removed from the filesystem.
CVE-2024-5056 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:L/A:L).
A CVSS v4 score has also been calculated for CVE-2024-5056. A base score of 6.9 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:L/VA:L/SC:N/SI:N/SA:N).
- CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Critical Manufacturing, Energy
- COMPANY HEADQUARTERS LOCATION: France
Yanis Wang of DAS-Security reported this vulnerability to Schneider Electric. Schneider Electric reported this vulnerability to CISA.
Modbus/TCP Ethernet Modicon M340 module: Version SV3.60 of BMXNOE0100 includes a fix for this vulnerability and is available for download here.
Modbus/TCP Ethernet Modicon M340 FactoryCast module: Version SV6.80 of BMXNOE0110 includes a fix for this vulnerability and is available for download here.
Schneider Electric is establishing a remediation plan for all future versions of Modicon M340 that will include a fix for this vulnerability. They will provide an update when the remediation is available. Until then, users should immediately apply the following mitigations to reduce the risk of exploit:
- Set up network segmentation and implement a firewall to block all unauthorized access to FTP port 21/TCP on the devices.
- FTP service is disabled by default. Deactivate the FTP service after use when not needed.
- Configure the Access Control List following the recommendations of the user manual "Modicon M340 for Ethernet Communications Modules and Processors User Manual" in chapter "Messaging Configuration Parameters".
For more information see the associated Schneider Electric CPCERT security advisory SEVD-2024-163-01, SEVD-2024-163-01 CSAF Version.
- September 11, 2025: Initial Republication of Schneider Electric CPCERT SEVD-2024-163-01
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-254-09
