Schneider Electric Plant iT/Brewmaxx
Successful exploitation of these vulnerabilities could risk privilege escalation, which could result in remote code execution.
The following versions of Schneider Electric Plant iT/Brewmaxx are affected:
  • Plant iT/Brewmaxx 9.60_and_above (CVE-2025-49844, CVE-2025-46817, CVE-2025-46818, CVE-2025-46819)
v3 9.9 Schneider Electric Schneider Electric Plant iT/Brewmaxx Use After Free, Integer Overflow or Wraparound, Improper Control of Generation of Code ('Code Injection')
  • Critical Infrastructure Sectors: Energy, Critical Manufacturing, Commercial Facilities
CVE-2025-49844
The affected product uses Redis, an open-source, in-memory database. Versions 8.2.1 and below allow an authenticated user to use a specially crafted Lua script to manipulate the garbage collector, trigger a use-after-free, and potentially lead to remote code execution.
Schneider Electric
Schneider Electric Plant iT/Brewmaxx: 9.60_and_above
Schneider Electric recommends users immediately apply the following mitigations to reduce the risk of exploit:
Install Patch ProLeiT-2025-001 via ProLeiT Support
https://www.proleit.com/support/
After installing ProLeiT-2025-001, disable the eval commands in Redis on the application server, VisuHub, engineering workstations, and workstations with emergency mode functionality
Force usage of secure Redis configuration templates in system settings as documented in the patch manual
Restart all patched servers and workstations
Schneider Electric strongly recommends the following industry cybersecurity best practices.
Locate control and safety system networks and remote devices behind firewalls and isolate them from the business network.
Install physical controls so no unauthorized personnel can access your industrial control and safety systems, components, peripheral equipment, and networks.
Place all controllers in locked cabinets and never leave them in the "Program" mode.
Never connect programming software to any network other than the network intended for that device.
Scan all methods of mobile data exchange with the isolated network such as CDs, USB drives, etc. before use in the terminals or any node connected to these networks.
Never allow mobile devices that have connected to any other network besides the intended network to connect to the safety or control networks without proper sanitation.
Minimize network exposure for all control system devices and systems and ensure that they are not accessible from the Internet.
When remote access is required, use secure methods, such as virtual private networks (VPNs). Recognize that VPNs may have vulnerabilities and should be updated to the most current version available. Also, understand that VPNs are only as secure as the connected devices.
For more information refer to the Schneider Electric Recommended Cybersecurity Best Practices document.
https://www.se.com/us/en/download/document/7EN52-0390/
For more information, see Schneider Electric security notification "SEVD-2026-013-01 Multiple Third-Party Vulnerabilities on ProLeiT Plant iT/Brewmaxx"
https://download.schneider-electric.com/files?p_Doc_Ref=SEVD-2026-013-01&p_enDocType=Security+and+Safety+Notice&p_File_Name=SEVD-2026-013-01.pdf
Relevant CWE: CWE-416 Use After Free
3.1 9.9 CRITICAL CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H
CVE-2025-46817
The affected product uses Redis, an open-source, in-memory database. Versions 8.2.1 and below allow an authenticated user to use a specially crafted Lua script to cause an integer overflow and potentially lead to remote code execution
Schneider Electric
Relevant CWE: CWE-190 Integer Overflow or Wraparound
3.1 7 HIGH CVSS:3.1/AV:L/AC:H/PR:L/UI:N/S:U/C:H/I:H/A:H
CVE-2025-46818
The affected product uses Redis, an open-source, in-memory database. Versions 8.2.1 and below allow an authenticated user to use a specially crafted Lua script to manipulate different LUA objects and potentially run their own code in the context of another user.
Schneider Electric
3.1 6 MEDIUM CVSS:3.1/AV:L/AC:H/PR:L/UI:R/S:U/C:H/I:H/A:N
CVE-2025-46819
The affected product uses Redis, an open-source, in-memory database. Versions 8.2.1 and below allow an authenticated user to use a specially crafted LUA script to read out-of-bound data or crash the server and subsequent denial of service.
Schneider Electric
3.1 6.3 MEDIUM CVSS:3.1/AV:L/AC:H/PR:L/UI:N/S:U/C:H/I:N/A:H
  • Schneider Electric reported these vulnerabilities to CISA
  • Initial Release Date: 2026-03-24
2026-03-24 1 Initial Republication of SEVD-2026-013-01
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-083-03
