Schneider Electric PowerChute Serial Shutdown
  • CVSS v3 7.8
  • Vendor: Schneider Electric
  • Equipment: PowerChute Serial Shutdown
  • Vulnerabilities: Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal'), Improper Restriction of Excessive Authentication Attempts, Incorrect Default Permissions
Successful exploitation of these vulnerabilities could allow an attacker to access user accounts or gain elevated system access.
The following version of Schneider Electric PowerChute Serial Shutdown are affected:
  • Schneider Electric PowerChute Serial Shutdown: Versions 1.3 and prior
3.2.1 IMPROPER LIMITATION OF A PATHNAME TO A RESTRICTED DIRECTORY ('PATH TRAVERSAL') CWE-22
A path traversal vulnerability exists that could cause elevated system access when a Web Admin user on the local network tampers with the POST/REST/UpdateJRE request payload.
CVE-2025-11565 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.0 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:H/PR:L/UI:N/S:U/C:H/I:H/A:H).
3.2.2 IMPROPER RESTRICTION OF EXCESSIVE AUTHENTICATION ATTEMPTS CWE-307
An improper restriction of excessive authentication attempts vulnerability exists that could allow an attacker on the local network to gain access to the user account by performing an arbitrary number of authentication attempts with different credentials on the /REST/shutdownnow endpoint.
CVE-2025-11566 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:L).
3.2.3 INCORRECT DEFAULT PERMISSIONS CWE-276
An incorrect default permissions vulnerability exists that could cause elevated system access when the target installation folder is not properly secured.
CVE-2025-11567 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
Aleksandar Djurdjevic reported these vulnerabilities to Schneider Electric. Schneider Electric reported these vulnerabilities to CISA.
  • PowerChute Serial Shutdown Versions v1.3 and prior: Version v1.4 of PowerChute Serial Shutdown includes a fix for these vulnerabilities and is available for download here:
  • (CVE-2025-11567) PowerChute Serial Shutdown Versions v1.3 and prior: To ensure remediation of CVE-2025-11567, users should immediately apply the following steps. If PowerChute is installed in a custom folder, ensure that the required permissions are set on the custom folder. NOTE: It is recommended to set administrative permissions on the custom folder. Specific instructions for these mitigations can be found in the Security Handbook.
  • PowerChute Serial Shutdown Version v1.4 installed on Microsoft Windows is a fixed version for CVE-2025-11565
  • PowerChute Serial Shutdown Version v1.4 installed on Red Hat Enterprise Linux is a fixed version for CVE-2025-11565
  • PowerChute Serial Shutdown Version v1.4 installed on SuSE Linux is a fixed version for CVE-2025-11565
  • PowerChute Serial Shutdown Version v1.4 installed on Microsoft Windows is a fixed version for CVE-2025-11566
  • PowerChute Serial Shutdown Version v1.4 installed on Red Hat Enterprise Linux is a fixed version for CVE-2025-11566
  • PowerChute Serial Shutdown Version v1.4 installed on SuSE Linux is a fixed version for CVE-2025-11566
  • PowerChute Serial Shutdown Version v1.4 installed on Microsoft Windows is a fixed version for CVE-2025-11567
  • PowerChute Serial Shutdown Version v1.4 installed on Red Hat Enterprise Linux is a fixed version for CVE-2025-11567
  • PowerChute Serial Shutdown Version v1.4 installed on SuSE Linux is a fixed version for CVE-2025-11567
For more information see the associated Schneider Electric CPCERT security advisory SEVD-2025-315-01 PowerChute Serial Shutdown - SEVD-2025-315-01 PDF Version, PowerChute Serial Shutdown - SEVD-2025-315-01 CSAF Version.
  • November 18, 2025: Initial Republication of Schneider Electric CPCERT SEVD-2025-315-01
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-322-04
