Schneider Electric System Monitor Application
  • CVSS v3 6.9
  • Vendor: Schneider Electric
  • Equipment: System Monitor Application
  • Vulnerability: Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting')
Successful exploitation of this vulnerability could allow an attacker to execute untrusted code.
Schneider Electric reports the following products are affected:
  • System Monitor application in Harmony Industrial PC series: All versions
  • System Monitor application in Pro-face Industrial PC series: All versions
3.2 Vulnerability Overview
3.2.1 IMPROPER NEUTRALIZATION OF INPUT DURING WEB PAGE GENERATION ('CROSS-SITE SCRIPTING') CWE-79
In jQuery versions greater than or equal to 1.0.3 and before 3.5.0, passing HTML containing
CVE-2020-11023 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.9 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:C/C:H/I:L/A:N).
Schneider Electric CPCERT reported this vulnerability to CISA.
  • Schneider Electric System Monitor application in Harmony Industrial PC series: Users can uninstall System Monitor application using the installer available for download here.
  • Please follow the steps described in the guideline attached as a PDF in the downloaded uninstaller guide.
  • Schneider Electric System Monitor application in Harmony Industrial PC series: If users choose not to apply the remediation provided above, they should immediately apply the following mitigations to reduce the risk of exploit:
    • Stop the system monitor if not required by turning off the services as specified in the Harmony Industrial PC Series User Manual.
    • Set up network segmentation and implement a firewall to block all unauthorized access to configured HTTP/HTTPS ports.
  • Schneider Electric System Monitor application in Pro-face Industrial PC series: Users can uninstall System Monitor application using the installer available for download here
  • Schneider Electric System Monitor application in Pro-face Industrial PC series: If users choose not to apply the remediation provided above, they should immediately apply the following mitigations to reduce the risk of exploit:
    • Stop the system monitor if not required by turning off the services as specified in the Pro-face PS5000 legacy industrial PC Series User Manual.
For more information see the associated Schneider Electric CPCERT security advisory SEVD-2025-189-02 System Monitor Application in Harmony and Pro-face PS5000 Legacy Industrial PCs - SEVD-2025-189-02 PDF Version, System Monitor Application in Harmony and Pro-face PS5000 Legacy Industrial PCs - SEVD-2025-189-02 CSAF Version.
  • July 22, 2025: Initial Republication of Schneider Electric CPCERT SEVD-2025-189-02
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-203-05
