SenseLive X3050
Successful exploitation of these vulnerabilities could allow an attacker to take complete control of the device.
The following versions of SenseLive X3050 are affected:
  • X3050 V1.523 (CVE-2026-40630, CVE-2026-25720, CVE-2026-35503, CVE-2026-39462, CVE-2026-27843, CVE-2026-40431, CVE-2026-40623, CVE-2026-27841, CVE-2026-40620, CVE-2026-35064, CVE-2026-25775)
v3 9.8 SenseLive SenseLive X3050 Authentication Bypass Using an Alternate Path or Channel, Insufficient Session Expiration, Use of Hard-coded Credentials, Insufficiently Protected Credentials, Missing Authentication for Critical Function, Cleartext Transmission of Sensitive Information, Missing Authorization, Cross-Site Request Forgery (CSRF)
  • Critical Infrastructure Sectors: Critical Manufacturing, Water and Wastewater, Energy, Information Technology
  • Company Headquarters Location: India
CVE-2026-40630
A vulnerability in the X3050's web management interface allows unauthorized access to certain configuration endpoints due to improper access control enforcement. An attacker with network access to the device may be able to bypass the intended authentication mechanism and directly interact with sensitive configuration functions.
SenseLive X3050
SenseLive
SenseLive X3050: V1.523
SenseLive did not respond to CISA's requests to coordinate. Affected users are encouraged to reach out to SenseLive for more information. https://senselive.io/contact
Relevant CWE: CWE-288 Authentication Bypass Using an Alternate Path or Channel
CVE-2026-25720
A vulnerability exists in the X3050's web management interface due to improper session lifetime enforcement, allowing authenticated sessions to remain active for extended periods without requiring re-authentication. An attacker with access to a previously authenticated session could continue interacting with administrative functions long after legitimate user activity has ceased.
SenseLive X3050
SenseLive
3.1 5.4 MEDIUM CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:L/I:L/A:N
CVE-2026-35503
A vulnerability in the X3050's web management interface allows authentication logic to be performed entirely on the client side, relying on hardcoded values within browser-executed scripts rather than server-side verification. An attacker with access to the login page could retrieve these exposed parameters and gain unauthorized access to administrative functionality.
SenseLive X3050
SenseLive
Relevant CWE: CWE-798 Use of Hard-coded Credentials
CVE-2026-39462
A vulnerability exists in the X3050's web management interface in which password updates are not reliably applied due to improper handling of credential changes on the backend. After the device undergoes a factory restore using the SenseLive Config 2.0 tool, the interface may indicate that the password update was successful; however, the system may continue to accept the previous or default credentials, demonstrating that the password-change process is not consistently enforced. Even after a factory reset, attempted password changes may fail to propagate correctly.
SenseLive X3050
SenseLive
3.1 8.1 HIGH CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:H
CVE-2026-27843
A vulnerability exists in the X3050's web management interface that allows critical configuration parameters to be modified without sufficient authentication or server-side validation. By applying unsupported or disruptive values to recovery mechanisms and network settings, an attacker can induce a persistent lockout state. Because the device lacks a physical reset button, recovery requires specialized technical access via the console to perform a factory reset, resulting in a total denial-of-service for the gateway and its connected RS-485 downstream systems.
SenseLive X3050
SenseLive
3.1 9.1 CRITICAL CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:H
CVE-2026-40431
A vulnerability exists in the X3050's web management interface due to its reliance on unencrypted HTTP for all administrative communication. Because management traffic, including authentication attempts and configuration data, is transmitted in cleartext, an attacker with access to the same network segment could intercept or observe sensitive operational information.
SenseLive X3050
SenseLive
3.1 5.3 MEDIUM CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:N/A:N
CVE-2026-40623
A vulnerability in the X3050's web management interface allows critical system and network configuration parameters to be modified without sufficient validation and safety controls. Due to inadequate enforcement of constraints on sensitive functions, parameters such as IP addressing, watchdog timers, reconnect intervals, and service ports can be set to unsupported or unsafe values. These configuration changes directly affect core device behaviour and recovery mechanisms. The lack of proper validation and safeguards allows critical system functions to be altered in a manner that can destabilize device operation or render the device persistently unavailable.
SenseLive X3050
SenseLive
Relevant CWE: CWE-862 Missing Authorization
3.1 8.1 HIGH CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:H/A:H
CVE-2026-27841
A vulnerability in the X3050's web management interface allows state-changing operations to be triggered without proper Cross-Site Request Forgery (CSRF) protections. Because the application does not enforce server-side validation of request origin or implement CSRF tokens, a malicious external webpage could cause a user's browser to submit unauthorized configuration requests to the device.
SenseLive X3050
SenseLive
Relevant CWE: CWE-352 Cross-Site Request Forgery (CSRF)
3.1 8.1 HIGH CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:U/C:N/I:H/A:H
CVE-2026-40620
A vulnerability in the X3050's embedded management service allows full administrative control to be established without any form of authentication or authorization on the SenseLive config application. The service accepts management connections from any reachable host, enabling unrestricted modification of critical configuration parameters, operational modes, and device state through a vendor-supplied or compatible client.
SenseLive X3050
SenseLive
CVE-2026-35064
A vulnerability in the X3050's management ecosystem allows unauthenticated discovery of deployed units through the vendor's management protocol, enabling identification of device presence, identifiers, and management interfaces without requiring credentials. Because discovery functions are exposed by the underlying service rather than gated by authentication, an attacker on the same network segment can rapidly enumerate targeted devices.
SenseLive X3050
SenseLive
3.1 7.5 HIGH CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N
CVE-2026-25775
A vulnerability in X3050's remote management service allows firmware retrieval and update operations to be performed without authentication or authorization. The service accepts firmware-related requests from any reachable host and does not verify user privileges, integrity of uploaded images, or the authenticity of provided firmware.
SenseLive X3050
SenseLive
  • Jithin Nambiar J reported these vulnerabilities to CISA
  • Initial Release Date: 2026-04-21
2026-04-21 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-111-12
