Shelly Pro 3EM
  • CVSS v4 8.3
  • Vendor: Shelly
  • Equipment: Pro 3EM
  • Vulnerability: Out-of-Bounds Read
Successful exploitation of this vulnerability could result in a denial-of-service condition.
The following version of Pro 3EM, a smart DIN rail switch, is affected:
  • Pro 3EM: all versions
3.2.1 OUT-OF-BOUNDS READ CWE-125
By sending a specially crafted Modbus request, an attacker can direct the device to access an illegal data address without standard error handling, causing the device to reboot and leading to a denial-of-service condition.
CVE-2025-12056 has been assigned to this vulnerability. A CVSS v3 base score of 7.4 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:C/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-12056. A base score of 8.3 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:H).
  • COMPANY HEADQUARTERS LOCATION: Bulgaria
Gabriele Quagliarella of Nozomi Networks reported this vulnerability to CISA.
Shelly did not respond to CISA's attempts at coordination. Users of Shelly Pro 3EM devices are encouraged to contact Shelly and keep their systems up to date.
  • November 18, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-322-03
