Multiple Siemens applications are affected by improper certificate validation in Siemens Analytics Toolkit. This could allow an unauthenticated remote attacker to perform man in the middle attacks. Siemens has released new versions for the affected products and recommends to update to the latest versions.
The following versions of Siemens Analytics Toolkit are affected:
- Siemens Software Center vers:intdot/<3.5.8.2 (CVE-2025-40745)
- Simcenter 3D vers:intdot/<2506.6000 (CVE-2025-40745)
- Simcenter Femap vers:intdot/<2506.0002 (CVE-2025-40745)
- Simcenter STAR-CCM+ vers:intdot/<2602 (CVE-2025-40745)
- Solid Edge SE2025
- Solid Edge SE2026
- Tecnomatix Plant Simulation vers:intdot/<2504.0008 (CVE-2025-40745)
| v3 3.7 | Siemens | Siemens Analytics Toolkit | Improper Certificate Validation |
CVE-2025-40745
Affected applications do not properly validate client certificates to connect to Analytics Service endpoint. This could allow an unauthenticated remote attacker to perform man in the middle attacks.
Siemens Software Center, Simcenter 3D, Simcenter Femap, Simcenter STAR-CCM+, Solid Edge SE2025, Solid Edge SE2026, Tecnomatix Plant Simulation
Update to V225.0 Update 13 or later version
https://support.sw.siemens.com/product/246738425/
Update to V226.0 Update 04 or later version
Update to V2504.0008 or later version
https://support.sw.siemens.com/product/297028302/
Update to V2506.0002 or later version
https://support.sw.siemens.com/product/275652363/
Update to V2506.6000 or later version
https://support.sw.siemens.com/product/289054037/
Update to V2602 or later version
https://support.sw.siemens.com/product/226870983/
Update to V3.5.8.2 or later version
https://www.sw.siemens.com/en-US/siemens-software-center/
Relevant CWE: CWE-295 Improper Certificate Validation
| 3.1 | 3.7 | LOW | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:L/I:N/A:N |
This ICSA is a verbatim republication of Siemens ProductCERT SSA-981622 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
- Initial Release Date: 2026-04-14
| 2026-04-14 | 1 | Publication Date |
| 2026-04-21 | 2 | Initial CISA Republication of Siemens ProductCERT SSA-981622 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-111-04
