Siemens Building X - Security Manager Edge Controller
  • CVSS v4 5.9
  • Equipment: Building X - Security Manager Edge Controller (ACC-AP)
  • Vulnerability: Improper Verification of Cryptographic Signature
Successful exploitation of this vulnerability could allow an attacker to upload maliciously modified firmware onto the device.
Siemens reports the following products are affected:
  • Building X - Security Manager Edge Controller (ACC-AP): All versions
3.2.1 IMPROPER VERIFICATION OF CRYPTOGRAPHIC SIGNATURE CWE-347
Affected devices do not properly check the integrity of firmware updates. This could allow a local attacker to upload maliciously modified firmware onto the device. In a second scenario, a remote attacker who is able to intercept the transfer of valid firmware from the server to the device could modify the firmware "on the fly".
CVE-2022-31807 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2022-31807. A base score of 5.9 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:P/PR:N/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
  • Building X - Security Manager Edge Controller (ACC-AP): Use the ACC Firmware App to apply updates in a controlled and authenticated manner, ensuring that only verified firmware packages from the official SIOS portal are installed on the controller. Validate the integrity of the downloaded firmware by confirming its hash value. Access to the controller should remain limited to authorized personnel, and credentials must be protected and updated according to policy to reduce the risk of unauthorized modifications or the installation of tampered firmware
  • Building X - Security Manager Edge Controller (ACC-AP): Currently no fix is planned
For more information see the associated Siemens security advisory SSA-420375 in HTML and CSAF.
  • December 11, 2025: Initial Republication of Siemens Product CERT SSA-420375
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-345-07
