Siemens Energy Services
  • CVSS v4 9.5
  • Equipment: Energy Services
  • Vulnerability: Incorrect Default Permissions
Successful exploitation of this vulnerability could allow an attacker to gain remote control of the G5DFR component and tamper outputs from the device.
  • Energy Services: All versions
3.2.1 INCORRECT DEFAULT PERMISSIONS CWE-276
Affected solutions using G5DFR contain default credentials. This could allow an attacker to gain control of G5DFR component and tamper with outputs from the device.
CVE-2025-40585 has been assigned to this vulnerability. A CVSS v3 base score of 9.9 has been assigned; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:C/C:L/I:H/A:L).
A CVSS v4 score has also been calculated for CVE-2025-40585. A base score of 9.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:N/UI:N/VC:H/VI:H/VA:H/SC:L/SI:H/SA:L).
  • Use the G5DFR web interface to change the default usernames, passwords and permission levels. Contact customer support for further assistance
For more information see the associated Siemens security advisory SSA-345750 in HTML and CSAF.
  • June 12, 2025: Initial Republication of Siemens SSA-345750
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-162-06
