Siemens Energy Services
  • CVSS v4 7.0
  • Equipment: Energy Services
  • Vulnerability: Authentication Bypass Using an Alternate Path or Channel
Successful exploitation of this vulnerability will allow an attacker to reset the Admin password.
  • Siemens Energy Services: All versions with G5DFR
3.2.1 AUTHENTICATION BYPASS USING AN ALTERNATE PATH OR CHANNEL CWE-288
On Elspec G5 devices through 1.2.2.19, a person with physical access to the device can reset the Admin password by inserting a USB drive (containing a publicly documented reset string) into a USB port.
CVE-2025-59392 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:P/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-59392. A base score of 7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:P/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
For more information see the associated Siemens security advisory SSA-734261 in HTML and CSAF.
  • December 11, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-345-08
