Siemens Engineering Platforms
  • CVSS v3 8.2
  • Equipment: Engineering Platforms
  • Vulnerability: Deserialization of Untrusted Data
Successful exploitation of this vulnerability could allow a local authenticated attacker to cause a type confusion and execute arbitrary code within the affected application and its privileges.
  • Siemens SIMATIC PCS neo V4.1: All Versions
  • Siemens SIMATIC WinCC V18: All Versions
  • Siemens SIMATIC WinCC V19: All versions prior to V19 Update 4
  • Siemens SIMATIC WinCC V20: All Versions
  • Siemens SIMOCODE ES V17: All Versions
  • Siemens SIMOCODE ES V18: All Versions
  • Siemens SIMOCODE ES V19: All Versions
  • Siemens SIMOCODE ES V20: All Versions
  • Siemens SIMOTION SCOUT TIA V5.4: All Versions
  • Siemens SIMOTION SCOUT TIA V5.5: All Versions
  • Siemens SIMOTION SCOUT TIA V5.6: All versions prior to V5.6 SP1 HF7
  • Siemens SIMATIC PCS neo V5.0: All Versions
  • Siemens SIMOTION SCOUT TIA V5.7: All Versions
  • Siemens SINAMICS Startdrive V17: All Versions
  • Siemens SINAMICS Startdrive V18: All Versions
  • Siemens SINAMICS Startdrive V19: All Versions
  • Siemens SINAMICS Startdrive V20: All Versions
  • Siemens SIRIUS Safety ES V17 (TIA Portal): All Versions
  • Siemens SIRIUS Safety ES V18 (TIA Portal): All Versions
  • Siemens SIRIUS Safety ES V19 (TIA Portal): All Versions
  • Siemens SIRIUS Safety ES V20 (TIA Portal): All Versions
  • Siemens SIRIUS Soft Starter ES V17 (TIA Portal): All Versions
  • Siemens SIMATIC PCS neo V6.0: All Versions
  • Siemens SIRIUS Soft Starter ES V18 (TIA Portal): All Versions
  • Siemens SIRIUS Soft Starter ES V19 (TIA Portal): All Versions
  • Siemens SIRIUS Soft Starter ES V20 (TIA Portal): All Versions
  • Siemens TIA Portal Cloud V17: All Versions
  • Siemens TIA Portal Cloud V18: All Versions
  • Siemens TIA Portal Cloud V19: All versions prior to 5.2.1.1
  • Siemens TIA Portal Cloud V20: All Versions
  • Siemens TIA Portal Test Suite V20: All Versions
  • Siemens SIMATIC S7-PLCSIM V17: All Versions
  • Siemens SIMATIC STEP 7 V17: All Versions
  • Siemens SIMATIC STEP 7 V18: All Versions
  • Siemens SIMATIC STEP 7 V19: All versions prior to V19 Update 4
  • Siemens SIMATIC STEP 7 V20: All Versions
  • Siemens SIMATIC WinCC V17: All Versions
3.2.1 DESERIALIZATION OF UNTRUSTED DATA CWE-502
Affected products do not properly sanitize Interprocess Communication input received through a Windows Named Pipe accessible to all local users. This could allow an authenticated local attacker to cause a type confusion and execute arbitrary code within the affected application.
CVE-2024-54678 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:R/S:C/C:H/I:H/A:H).
  • All affected products on Desktop systems: Execute affected software on Windows hosts where only a single user is configured
  • All affected products on Server systems: Reduce the access on operating system level to administrators only
  • SIMATIC PCS neo V4.1, SIMATIC S7-PLCSIM V17: Currently no fix is planned
  • SIMATIC PCS neo V5.0, SIMATIC PCS neo V6.0, SIMATIC STEP 7 V17, SIMATIC STEP 7 V18, SIMATIC STEP 7 V20, SIMATIC WinCC V17, SIMATIC WinCC V18, SIMATIC WinCC V20, SIMOCODE ES V17, SIMOCODE ES V18, SIMOCODE ES V19, SIMOCODE ES V20, SIMOTION SCOUT TIA V5.4, SIMOTION SCOUT TIA V5.5, SIMOTION SCOUT TIA V5.7, SINAMICS Startdrive V17, SINAMICS Startdrive V18, SINAMICS Startdrive V19, SINAMICS Startdrive V20, SIRIUS Safety ES V17 (TIA Portal), SIRIUS Safety ES V18 (TIA Portal), SIRIUS Safety ES V19 (TIA Portal), SIRIUS Safety ES V20 (TIA Portal), SIRIUS Soft Starter ES V17 (TIA Portal), SIRIUS Soft Starter ES V18 (TIA Portal), SIRIUS Soft Starter ES V19 (TIA Portal), SIRIUS Soft Starter ES V20 (TIA Portal), TIA Portal Cloud V17, TIA Portal Cloud V18, TIA Portal Cloud V20, TIA Portal Test Suite V20: Currently no fix is available
For more information see the associated Siemens security advisory SSA-693808 in HTML and CSAF.
  • August 14, 2025: Initial Republication of Siemens ProductCERT SSA-693808
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-03
