Heliox EV Chargers listed below contain improper access control vulnerability that could allow an attacker to reach unauthorized services via the charging cable. Siemens has released new versions for the affected products and recommends to update to the latest versions.
The following versions of Siemens Heliox EV Chargers are affected:
- Heliox Flex 180 kW EV Charging Station
- Heliox Mobile DC 40 kW EV Charging Station
| v3 2.6 | Siemens | Siemens Heliox EV Chargers | Improper Restriction of Communication Channel to Intended Endpoints |
CVE-2025-27769
Affected devices contain improper access control that could allow an attacker to reach unauthorized services via the charging cable.
Heliox Flex 180 kW EV Charging Station, Heliox Mobile DC 40 kW EV Charging Station
Contact customer support for patch information via OTA update
Relevant CWE: CWE-923 Improper Restriction of Communication Channel to Intended Endpoints
| 3.1 | 2.6 | LOW | CVSS:3.1/AV:P/AC:L/PR:N/UI:N/S:C/C:L/I:N/A:N |
This ICSA is a verbatim republication of Siemens ProductCERT SSA-126399 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
- Initial Release Date: 2026-03-10
| 2026-03-10 | 1 | Publication Date |
| 2026-03-12 | 2 | Initial CISA Republication of Siemens ProductCERT SSA-126399 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-071-05
