Siemens Industrial Edge Management OS (IEM-OS)
  • Equipment: Industrial Edge Management OS (IEM-OS)
  • Vulnerability: Allocation of Resources Without Limits or Throttling
Successful exploitation of this vulnerability could allow a remote attacker to cause a denial-of-service condition.
  • Industrial Edge Management OS (IEM-OS): All versions
3.2.1 ALLOCATION OF RESOURCES WITHOUT LIMITS OR THROTTLING CWE-770
Allocation of resources for multipart headers with insufficient limits enables a denial-of-service vulnerability in Apache Commons FileUpload.
CVE-2025-48976 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-48976. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
  • Migrate to Industrial Edge Management Virtual (IEM-V).
  • Limit access to trusted users and systems only.
For more information, see the associated Siemens security advisory SSA-640476 in HTML and CSAF.
  • When remote access is required, use more secure methods, such as virtual private networks (VPNs). Recognize VPNs may have vulnerabilities, should be updated to the most recent version available, and are only as secure as the connected devices.
  • September 11, 2025: Initial Republication of Siemens SSA-640476
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-254-06
