Industrial Edge Management contains an authorization bypass vulnerability that could be exploited by an unauthenticated remote attacker to circumvent authentication and to access connected Industrial Edge Devices through the remote connection feature. Siemens has released new versions for the affected products and recommends to update to the latest versions.
The following versions of Siemens Industrial Edge Management are affected:
- Industrial Edge Management Pro V1 vers:intdot/>=1.7.6|<1.15.17 (CVE-2026-33892)
- Industrial Edge Management Pro V2 vers:intdot/>=2.0.0|<2.1.1 (CVE-2026-33892)
- Industrial Edge Management Virtual vers:intdot/>=2.2.0|<2.8.0 (CVE-2026-33892)
| v3 7.1 | Siemens | Siemens Industrial Edge Management | Authentication Bypass by Primary Weakness |
CVE-2026-33892
Affected management systems do not properly enforce user authentication on remote connections to devices. This could facilitate an unauthenticated remote attacker to circumvent authentication and impersonate a legitimate user. Successful exploitation requires that the attacker has identified the header and port used for remote connections to devices and that the remote connection feature is enabled for the device. Exploitation allows the attacker to tunnel to the device. Security features on this device itself (e.g. app specific authentication) are not affected.
Industrial Edge Management Pro V1, Industrial Edge Management Pro V2, Industrial Edge Management Virtual
Ensure network access to affected products is limited to trusted parties only
Update to V1.15.17 or later version
https://iehub.eu1.edge.siemens.cloud/
Update to V2.1.1 or later version
Update to V2.8.0 or later version
Relevant CWE: CWE-305 Authentication Bypass by Primary Weakness
| 3.1 | 7.1 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:C/C:L/I:L/A:L |
This ICSA is a verbatim republication of Siemens ProductCERT SSA-609469 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
- Initial Release Date: 2026-04-14
| 2026-04-14 | 1 | Publication Date |
| 2026-04-21 | 2 | Initial CISA Republication of Siemens ProductCERT SSA-609469 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-111-11
